Results 1 to 10 of 18
Thread: Strut Brace
    Regular Member Damian's Avatar
    Market Drayton
    Default Strut Brace
    Could somebody please post some pictures or a quick How 2 onto where and how to fit a strut brace into my Vectra C engine bay
    Regular Member Harry's Avatar
    Uxbridge, London
    which strut brace have ou bought?? the Regal one?
    Market Drayton
    I got it from Regal, but it doesn't say regal on it, it says Wiechers Sport
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    best person to ask would be Micky (AF) mate. he's fitted the regal one on his motor.
    Market Drayton
    Good thinking, will drop him a PM
    Getting my Eibach Pro Springs fitted tomorrow morning as well, I should have a handling dream soon !!!
    Market Drayton
    Had a quick look in my engine bay and it looks fairly straight forward except for the 'screw' type thinks that I need to undo. See Micky's thread here
    Anyone know what they are called so I can get something to remove them
    Uxbridge, London
    you mean the torx screws? any halfords type shop will stock a set.
    Uxbridge, London
    you may need some washers to put under the strut brace in order to lift enough to miss the brake fluid reservoir that sits over to the drivers side of the engine bay.
    the same strut brace would not fit on my car despite it be fitted on others cars with the exact same engine! very strange. when fitted.....i'd try to close the bonnet and before it even went onto the catch the bonnet would flex pretty violently.
    in the end, i had to send it back.
    just make sure that the strut brace does not put any pressure on the reservoir! asking for trouble otherwise.
    Market Drayton
    Yep, it fits with the bonnet lid down but it is putting pressure on the resevoir, I don't even think that washers will help because then the screws would not be long enough !!!!
    Uxbridge, London
    depends by how much the bar is pushing down on the reservoir. it should only need raising by 3mm, and two big washers normally do this. there will still be sufficient thread to hold everything together.
    try also using the adjustment on each side of the bar to miss the reservoir.
    does take a bit of fiddling, but hopefully you should be able to get it to sit right.
  1. strut brace
    By sparky3865 in forum Handling & Braking
    Last Post: 8th May 2012, 13:35
  2. Strut brace on 1.8 VVT
    By 0uT1aW in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2011, 23:46
  3. Strut brace
    By Danwells72 in forum Handling & Braking
    Last Post: 2nd September 2009, 19:26
