Results 1 to 2 of 2
Thread: Rubber door trim
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Rubber door trim
    Is it possible to get the sealing rubber strip off without damaging them?...
    Regular Member Tallywhacker's Avatar
    Feb 2009
    coventry
    yes....whole rubber seal and window channels are in one piece, but it means stripping door casing and wing mirror off, front of rubber strip at the inner part in front of wing mirror has a small screw at the edge and you have to wind doorglass down and remove rubber/felt strip out of channel first which then expose 3 screws at back edge of channel which you need to take out so you can seperate metal fascia on outer back edge of the door.
    Then you can begin to seperate rest of seal around doorframe(it is quite tight and has aluminium inserts so be careful not to bend out of shape)
  1. Diesel Rubber Trim Above Radiator
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2012, 12:46
  2. Rubber trim around the windows
    By Mark-R in forum Detailing and Car Care Discussion
    Last Post: 28th August 2012, 12:14
  3. rubber door trim
    By nikroc in forum Bodywork & Interior
    Last Post: 1st July 2011, 20:20
  4. rubber trim and door seals
    By WKD-mcc in forum Detailing and Car Care Discussion
    Last Post: 2nd May 2009, 18:10
