Results 1 to 3 of 3
Thread: Swirl linkagel
    Jul 2011
    birmingham
    Smile Swirl linkagel
    Hi all. Having removed and repaired swirl bar is there a right and wrong way round to refit it. When should i see the swirl motor move. Should it move when I rev the engine? Also where do you get erg blanking plates from. If you blank off do you have to reprogramme ecu. Last of all where is the fault reader connecter.
    All running fine 103000 miles 45 mpg 1.9 150.
    Thanks in advance
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    I believe the swirl bar moves when revving yes but not 100% sure.
    You can get blanking plates from ebay for about £3, I made a How 2 for the 1.9 150
    http://www.vectra-c.com/forum/showthread.php?t=146320
    After blanking the engine management light will come on, it will do no harm but if it gets on your nerves you can have it mapped out for around £100 I think.
    The connector is underneath the ashtray infront of your gear stick, just open the flap then remove the little tray.
    Jul 2011
    birmingham
    Thanks John
  1. Swirl Bar help please
    By elle2801 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 21:28
  2. swirl bar off
    By vectraross in forum Engine & Drivetrain
    Last Post: 20th August 2012, 12:12
  3. Swirl bar
    By MickAP in forum Engine & Drivetrain
    Last Post: 13th January 2012, 19:14
  4. Swirl x
    By dannyp in forum Detailing and Car Care Discussion
    Last Post: 22nd August 2011, 17:59
  5. swirl or not to swirl
    By lesron in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 19:53
