Thread: using oil
    Jan 2010
    WEST YORKSHIRE
    Default using oil
    wondered if anybody could help with a problem i have with my 2006 8v 1.9cdti veccy.
    about two weeeks ago checked oil level and she needed topping up,did so,but it has got to the point now that shes using 1litre of engine oil every 200 miles.
    not smoking excessivly unless u give it some through the gears,but u can smell the oil while on tickover.
    now my header tank above the water line is coated in what looks like black oil,but if you scrape it off,it just seems to roll into balls rather than smear,and no mayonaise looking water either,in fact water appears clear.
    have noticed on cold start up a lot of blue smoke for about twenty seconds then just the oil smell but no excessive smoke as such,and i am at a loss what it could be,no loss of power no warning lights just major oil usage,but the car has covered 232000 miles,any help would be appreciated.
    oh and not using water either,help!!!!
    Jan 2010
    WEST YORKSHIRE
    could it be
    1 head gasket?
    2 oil cooler?
    3 rings?
    4 valve stem seals?
    changed turbo already bcos was told it was turbo seals that had gone.
    Jan 2010
    WEST YORKSHIRE
    Default using oil
    anybody any ideas?
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Valve stem seals I reckon as blue smoke on start up usually points to valve stems
    Apr 2011
    Toulon, France
    Quote Originally Posted by chaosmunkey27 View Post
    could it be
    1 head gasket?
    2 oil cooler?
    3 rings?
    4 valve stem seals?
    Surely head gasket if a line like you say in the tank?
    Jan 2010
    WEST YORKSHIRE
    head gasket a possibility but its coated just above the water line but hasnt gone like mayonaise,in fact its not mixed with water at all,very weird
    Jan 2010
    WEST YORKSHIRE
    its just lined the header tank above the water line,pure black
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by tanya_baby View Post
    If the black line is just above the water level in the tank...
    Remember the coolant will rise when warmed up, and drop when cool again
    Head gasket a real possibility here
    Dec 2010
    wisbech
    ive been using semi sythetic oil 10w40, as thicker oil is better when mileage starts getting high less oil seapage past seals etc
    Coventry
    Hi.
    Sounds like worn valve stem seals dude
    As you say no loss of power , All diesels smoke under power/acceleration.
    Good luck
