Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: HIDs poor?
    Regular Member bigdave1701's Avatar
    York
    Default HIDs poor?
    Driving home from my parents tonight I was quite looking forward to using my newly installed HIDs but feel really disappointed with them! The light is beautifully white but still only projects 10ft in front of the car with a very definite line in the beam where the light stops! Is it possible that at some point the lights have been adjusted too low?
    scottish region
    It's the vectra headlights there ****
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Silly question but have you adjusted the adjuster in the car to setting 1? I have also found that they take a couple of hours usage to fully bed in, after that they are brighter, but this may not be your issue here.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Hid's and 10ft distance hmmmmmmmm...........
    sommit nae right there.
    Full Member
    South West
    The vectra headlight units are fine in my opinion and work a charm with HIDS.
    What is suspect you have done is exactly what i did... I installed mine and was disappoionted to start... same as you beam only 10ft in front of the car. Drove like this for ages.
    You will probably find that you have inserted them into the headlight block wrong. With mine, where they appeared to be fitted correctly they were in fact wrong. The bulbs needed to be rotated as they will actually locate in the headlight block in two different locations.
    Pull the bulbs out and rotate them around until the lugs line up again and push back into position. Make sure they are pushed fully home and i expect that will give you the correct light alignment.
    If its the same with yours, then when fitted correctly you will understand why its such a good upgrade
    York
    Is yours a preface? as I'm fairly sure the facelift bulbs only fit one way
    York
    I had the same definitive line where the light stopped with the standard bulbs which is what makes me think the issue is the level of the lights rather than the new bulbs.
    *EDIT*
    Yes they're set to '0' on the dash (people keep saying 1 but my dial runs from 0-4)
    Engine : 1.9 CDTi
    Get them aligned to make sure they are set right.
    Jul 2010
    Londonderry Northern Ireland
    Quote Originally Posted by Aidi View Post
    x2 quite common on facelift vectras
    York
    Had the passenger side light out and fiddled until it'd go in a different location (not easy to do) and in the new location you can tell it's wrong as only 1/2 the projector lights up! I've put it back where it was and will get them properly aligned tomorrow morning.
  1. My poor poor veccy :(
    By tammyman09 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2011, 10:46
  2. Poor kid......
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 26th March 2009, 17:46
  3. poor mpg what should it be?
    By phil18_1 in forum Engine & Drivetrain
    Last Post: 10th March 2008, 19:22
  4. Nooooooo!!!!, my poor, poor car!!
    By Duncan in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2006, 16:32
  5. My Poor Poor Signum
    By Brake buster in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2005, 15:45
