Thread: Leaking oil filter.
    Regular Member xoborp's Avatar
    Default Leaking oil filter.
    My oil warning light started flashing today, so i pulled over to check it, bearing in mind i had changed the oil only two months ago.
    My engine has always been as dry as anything with no leaks whatsoever.
    When i got under the bonnet, there was oil all under the filter on the engine and some on the gearbox.
    When i felt under the oil filter i got oil all over my hand, so i wiped it again and again and then there was none, so i topped the oil up and the flashing stopped, drove to my friends to have it looked at and the same happened again, touched the oil filter and it was covered in oil underneath.
    The light has stayed off so far, so has the oil filter broke, or the seal gone?
    When i changed the oil a couple of months ago, i did try and get the filter off but couldnt budge it, i stopped trying when paint off the filter was coming off.
    Could it be that i have damaged the oil filter then, and now it is giving me nightmares.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Yes chances are yes you damaged the filter trying to get it off. Which engine is it? When I got mine it was obvious it had not had a filter in a while and I had to use a long screwdriver and a hammer, made a notch in the rim of the filter and knocked it round with the screwdriver and hammer to get it off.
    Hi,
    It is a 2004 1.8 Club Estate.
    Cant understand why it has started now, as it must be 2 months since i changed the oil.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Years ago I remember a similar incident with a mate and a MKII escort, his filter was damaged and eventually it burst. Did you get a better chance to have a look today?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Could just be you managed to undo the seal just slightly
    Or could be that filter it's self is split I've seen a few cars with that happen
    Really need to get filter off an change
  1. Leaking diesel from under filter can
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 24th February 2013, 23:15
  2. 1.9 cdti vectra fuel filter leaking
    By felix_19 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2012, 16:47
  3. Leaking filter
    By anthonynoelg in forum Vectra C / Signum Troubleshooting
    Last Post: 4th May 2011, 08:33
  4. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  5. oil leaking from filter housing
    By dicky3706 in forum Engine & Drivetrain
    Last Post: 30th November 2010, 11:01
