Thread: How to improve the power of my vec turbo???
    Regular Member J's Turbo's Avatar
    Sep 2011
    luton
    Default How to improve the power of my vec turbo???
    Guys can you advise me on how i can boost the power of my car? Your advice would be much appreciated.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Maptun, BSR stage 1 is good but the support is rubbish.HTH
    Sep 2011
    luton
    Quote Originally Posted by Super T View Post
    cool thanks bud!
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The BSR maps are good and well tested, but as said the support is pathetic, personally I wouldn't touch BSR with a barge pole. There's a lot of other re-mappers out there from the smaller guys (search the forum for Torquing BHP as Daryl has a very good reputation on here) or the bigger guys like Maptun that myself and a few others have dealt with. There's hundreds of them so do your research and go for what you feel suits you best with the budget you have to play with.
    Nov 2010
    bracknell
    You could also make mechanical adjustments and fit a bleed valve, There alot of bad hype about running lean etc.. but i have run one since owning the car and have had no probs and no spikes. If setup properly you can gain nice power and so much more pickup.
    Again this is only my opinion but it worked fine for me and changed the car into a quick little runner and at a cost of no more than £20.
    There are horror stories though but if you wanted to go this route i would be happy to help you and set you up also you could see mine and feel what its like.
    i have run mine redlined in most gears and it fuels fine and the turbo is only boosting slightly more so not over working it.
    maybe a cheap option depending on your budget.
  1. modified hose fixed turbo lag and no power cdti
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 11th May 2010, 22:41
  2. Loss of Power / Turbo Lag?
    By sirk696 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2010, 22:59
  3. Replies: 7
    Last Post: 27th November 2009, 19:43
  4. vectra sri turbo 2.0 differnce in power
    By abeckett in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2009, 22:49
  5. loss of power-- turbo??
    By formby in forum Engine & Drivetrain
    Last Post: 16th September 2008, 09:11
