Hi,I have a prob. with rear fog light passenger side,bc said replace bulb,(replaced)still doesn't work.Any help will be great before going to garage.Maybe something easy which I can fix it.Thanks for any help.
have you tried the fuse this may be the reason
The nearside rear fog lamp although fitted with a bulb is not wired up at the factory, some owners run a wire from the offside fog to the nearside one to get it to work.
All Vec c models have only one working rear fog when they leave the factory.
They was working both,my veccy is 1.8 sri vvt 07reg.And I don't know(the fuse) which one is,on the manual doesn't show,thanks for the help...
The left hand side rear fog light is not wired in as standard. Yes there is still a bulb in there. A lot of members have wired theirs so the left dors work though. That may be the case with your previous Vectra.
Is this the same on the siggy
Thanks I will look tomorrow.Thanks to all you gays
Moved to the electrical trouble shooting section
