Thread: vec c gearbox oil and plug
    Sep 2011
    Essex
    Default vec c gearbox oil and plug
    hi guys.
    i have taken the gearbox plug out by mistake thinking (well obviously i wasnt)
    it was the sump plug. how do i get the new gearbox oil back in the box?
    its a cdti 1.9
    cheers
    Mileage : 000
    I pour mine in through the reversing sensor switch.
    Sep 2011
    Essex
    ?????????????? wheres that mate?
    The top up plug in the top of the F40 manual gearbox requres an 8mm allen key to remove it if my memory serves me right. You will more than likely have to remove the battery and the battery box to access the filler plug. If the box is totally empty you should put 2.4 litres back in, this is the recommended amount of oil revised by Vaux to allow smoother gear changes.
    Mileage : 000
    Quote Originally Posted by -stuuby- View Post
    On the F35 it is on the top there is a wire with a plug on it. I would presume your reversing sensor is in a simalar place.
    Aug 2010
    Derbyshire
    The How to is here http://www.vectra-c.com/forum/showthread.php?t=114196
    I got T45 and T50 torx bits for this job as the link says above. Easy enough to do, just need a long extension to get at the fill plug. No need to remove the battery and box. Never needed new plugs either, just reused the originals with thread sealing tape. This job is easier than an engine oil change on this engine, the filter is a bit of a pain to get at.
    Mick
  1. F40 gearbox oil plug, what size?
    By yysnet in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2016, 02:03
  2. :( So Fed Up - Gearbox spat out the drain plug!!!!
    Last Post: 12th July 2012, 09:28
  3. gearbox drain plug
    By collyb in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 13:47
  4. Gearbox oil drain plug
    By big nath in forum Engine & Drivetrain
    Last Post: 15th February 2011, 18:13
  5. gearbox drain plug magnet
    By tugger434 in forum Engine & Drivetrain
    Last Post: 5th March 2010, 14:35
vauxhall vectra c gear box oil filler
vectra 2007 manual gearbox sump plug
vectra c gearbox drain plug www.vectra-c.com
