Results 1 to 10 of 18
Thread: New battery fitted and its still going flat ??
    Regular Member m8wos's Avatar
    Jan 2008
    bedford
    Default New battery fitted and its still going flat ??
    i was suffering from a flat battery so went to the shop bought new one and got it fitted, but im still getting a flat battery ...any ideas cos its doing my head in.
    everything else is ok on the car as far as i no.
    signum 1.9 tdi auto
    thanks
    warren
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    on my 2.2dti i had the cause of my flat battery turned out to be the aircon wasnt dissengaging itself and was draining battery??? dont ask me how thats just what my mate said and after he fiddled on it was sorted matey
    cheers
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Have u checked the bootlight is going out ?
    also, glove box light, alternator not holding charge.........
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Did you check the voltage across the battery with the car running before you bought the battery?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Did you let the electrical system die of completely when you changed the battery?
    ie, was the car with no battery for a few minutes?
    If not that might be an idea in case one module is not shutting down completely because of a software problem.
    Assuming it's not bulbs as mentioned above you need to use a multimeter to measure the current flowing out of the battery with the car locked and the bonnet open switch pressed in.
    Not easy to do, you will probably need 2 people.
    Once you get an idea of how much the current flow is then some ideas might come to mind.
    Removing fuses (and then locking the car) isolates individual circuits, but it is a hit and miss job and easy to lose track of where your up to.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by m8wos View Post
    signum 1.9 tdi auto
    thanks
    warren
    How long does it last before going flat - are you sure your alternator is working ok - it should be putting out around 14.4 volts with the engine running and no load. Also was the battery fully charged when you bought it - if they have had it in storage for a long time it could be discharged or it could even be defective.
    Jan 2008
    bedford
    just plugged in my op-com and got the following
    battery runnining at 13.7 volts plus these but dont understand..
    OP-COM - CAN Communication Window> 2006 (6)|Vectra-C / Signum|Engine|Z 19 DTH
    Read Info...
    Identifier: 0x075D
    VIN: W0L0ZCF4861109268
    Hardware number:81013409
    Motor type: Z19DTH
    Part Number:55205632
    Software version number: WJOAS100_S
    Hardware manufacturer number: 0281013409
    Software Number: 1037383690P319_O90
    Programming Date: 20070208
    Hardware key number: S001001044
    System description: BOSCH0100
    Type approval number: B05010
    Variant programming: 0x00006094
    Alpha code: ES
    Hardware manufacturer system name: EDC16
    Software version: O90JTD75
    ECU variant coding: 0x00003BC0
    Total number of fault codes: 6
    P0560 - System Voltage Low Input
    (12) - Not present
    P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    (5A) - Not present
    P0070 - Ambient Air Temperature Sensor Malfunction
    (74) - Not present
    U2108 - CAN-Bus no Communication with ABS/TC
    (70) - Not present
    P0500 - Vehicle Speed Signal Range/Performance
    (7E) - Not present
    (7F) - Not present
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    clear the codes go for a run and read it again just in case the codes are from a previous problem
    Regular Member poves's Avatar
    lancashire
    Start with the simple things first , the a3 project I'm working on at the moment had the same issue , even with a new battery.
    It ended up being the vanity mirror light in the drivers visor was staying illuminated , the switch on the slider was faulty.
    The only thing I would say is 13.7v seems a little low , from what I have read a healthy charging system should average between 14v - 14.8v .
  1. Flat Battery - AGAIN!
    By Keif in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2011, 21:47
  2. Flat battery... Coincidence that I've just fitted reverse sensors?
    By DNS in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2011, 18:05
  3. Flat battery, I think
    By Hideous in forum Engine & Drivetrain
    Last Post: 29th December 2007, 20:50
  4. battery going flat
    By kevin in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2006, 12:35
  5. Help, flat battery
    By Matt21385 in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2006, 20:55
vectra c new battery alternator charging and still flat battery
i have fitted a new battery on my car but battery still goes flat what else can it be
