Thread: misfire on idle... possible fuel pump???
    Regular Member vectra100turbo's Avatar
    manchester
    Default misfire on idle... possible fuel pump???
    hi all still have misfire on idle until i rev it up by about 200 revs on my 2.0t, but drives fine at any speed and has loads of power at any rev range. done usual plugs, coils, even exhaust sensors and turbo but still there. its not as bad with air con on but bad without. anyone know if it could be fuel pump related? i get no fault codes on opcom
    May 2011
    bispham, blackpool
    havent a clue carl but hopfully someone has been through the same problem and might have a answer
    manchester
    Quote Originally Posted by 6009tristanb View Post
    hahaha hows ya!!! thinkin of gettin new pump so wondered if it worth it..
    you comin up later
    May 2011
    bispham, blackpool
    yeah will be their in a bit just waiting for kirsten to finsh work
    fuel pump is the only option left i think
    or another option could be anyone know if vx has done a softwear upgrade for the edition 100 on a 03 reg
    or could a remap sort this out as the car runs mint once the revs go up by around 200rpm and they could just map the ecu to let it tick over fine
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Sounds daft but are correct plugs fitted?
    Other things to check are all the breather ok. Or could be possible leak into inlet system. Sticky throttle valve.
    Can you get a data reading to see what it happening at idle.
    manchester
    Quote Originally Posted by CritchvxD View Post
    hi yeah checked plugs ang pipework do you know what i can use to get live data readings thanks
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Need some sort of diagnostics mate.
  1. Signum 2.2 direct misfire - fuel pump?
    By jgs1000 in forum Engine & Drivetrain
    Last Post: 4th May 2012, 05:33
  2. Misfire at idle
    By mechman458 in forum Engine & Drivetrain
    Last Post: 12th March 2012, 14:13
  3. misfire on idle... possible fuel pump???
    By vectra100turbo in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2011, 09:23
  4. misfire at idle
    By billroy in forum Engine & Drivetrain
    Last Post: 14th November 2010, 01:11
  5. Misfire - even at idle when hot
    By muctm in forum Engine & Drivetrain
    Last Post: 13th June 2008, 12:07
