Thread: Vectra c clucking from drivers side wheel (cracking metal sound)??
    Aug 2011
    Hull, UK
    Unhappy Vectra c clucking from drivers side wheel (cracking metal sound)??
    Hi,
    I have a strange problem with my vectra c 04 plate of which i have tried everything to fix and nothing seems to have fixed the problem so far (driving me nuts now).
    Its hard to describe but it sounds like a metal bolt snapping when hitting a pot hole, over speed ramps some times, turning corners. brakeing or setting off fast.
    Below is what i have done so far: -
    Bottom arms / Wishbones (both sides) = REPLACED NEW (aftermarket)
    track rod ends (both sides) = REPLACED NEW (aftermarket)
    link arms (both sides) = REPLACED NEW (aftermarket)
    Brake Pads mintex (both sides) = REPLACED NEW (aftermarket)
    Anti roll bar bushes (both sides) = REPLACED NEW (aftermarket)
    Drive Shafts = REPLACED USED (off a scrap car)
    Springs / shockers checked in good condition new rubber seat added to springs (both sides) NEW (from dealers)
    Any ideas this has cost me a small furtunes so far and i still have the same problem??
    Regards,
    Smith Online
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    it sounds a bit like you need new strut top bearing
    http://www.vectra-c.com/forum/showthread.php?t=101367
    Aug 2011
    Hull, UK
    Ok , next job change strut top. Will let you know if this solves it
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Have u checked engine mounts
  1. fclunking noise coming from front drivers side wheel
    By dti owner in forum Vectra C / Signum Troubleshooting
    Last Post: 24th February 2013, 17:15
  2. Vectra-B brakes sound like metal to metal
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2011, 14:42
  3. Knocking Sound From Drivers Front Wheel
    By corderz in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2011, 03:10
  4. metal sound?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 12:04
