Results 1 to 10 of 11
Thread: 1.9cdti judder and loss of power then fine.
    Regular Member voxvectra7's Avatar
    Apr 2011
    Wigan, UK
    confused 1.9cdti judder and loss of power then fine.
    Driving into work I was doing around 55-60mph when the car suddenley felt like it was driving over heavily painted road markings/ hatchings. So this judder lasted probably around 10 seconds and with it seemed a loss of any extra power. I was overtaking a lorry and maintained it's speed even tho my foot was down trying to accelerate. Then as in an instant it was fine. Mentioned it to my mrs and it's done this twice for her.
    Anyone any idea what I should check or what the prob may be?
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    your missus started to put petrol in when filling up didnt she!!! lol
    Coventry
    Hi voxvectra7
    This happened with out veccy also, after replacing the Egr valve it hasnt happened since.
    Good luck m8
    Apr 2011
    Wigan, UK
    Quote Originally Posted by stopi View Post
    Hi voxvectra7
    Good luck m8
    Thanks for the reply mate. Is the EGR valve replacement a big and costly job?
    Regular Member DeJohnny's Avatar
    Jun 2011
    belgium
    Quote Originally Posted by voxvectra7 View Post
    Not much work to do yourself, just need to activate the new valve with tech 2, and buy the egr in a local fiat dealer, about 130€ instead of 180€ opel/vauxhall. Dont know how much pound 1€ is. Sry
    Jun 2011
    belgium
    Just try unplugging the egr-valve before buying a new one, if it doesn't judder then its without doubt egr
    Coventry
    Hi vox. No it's not an expensive job. Here is a link to a brand-new genuine part http://www.ebay.co.uk/itm/VAUXHALL-E...e#ht_763wt_689
    fitting is simple also. If you need more info gis a shout.
    Good luck
    Regular Member J's Turbo's Avatar
    Sep 2011
    luton
    In the garage we get the same sort of problem try cleaning it first and see if that works most likely theres gunk in there.
    Sep 2011
    luton
    Quote Originally Posted by DeJohnny View Post
    you can look for 2nd hand one for about £40 or new one £100
    Apr 2011
    Wigan, UK
    A big thanks to everyone for your help with this one. Because the judder has only occurred maybe 3 times tops, is it likely to be the EGR? I read the de- coke thread and thought about buying either the £20 10k boost or the wynns EGR 3 can for £6. Any thoughts on this or do I really need to get the EGR valve taken off n cleaned or replaced?
    Your thoughts on this would help possibly save me some dosh.
    Many thanks forum.
  1. Power loss, judder under acceleration
    By JonnyB_UK in forum Y & Z30DT Specific
    Last Post: 14th August 2012, 12:06
  2. Loss of power, 1.9cdti sri 150
    By Lee_Pike in forum Engine & Drivetrain
    Last Post: 16th May 2012, 23:08
  3. CDTI 150 Intermittent loss of power/judder
    By Campos1 in forum Engine & Drivetrain
    Last Post: 13th March 2012, 20:07
  4. Loss of power and engine judder in 5th and 6th
    By gdansk in forum Engine & Drivetrain
    Last Post: 23rd September 2011, 15:08
  5. v6 cdti judder/loss of power
    By rickyhopkins in forum Engine & Drivetrain
    Last Post: 12th April 2009, 00:30
why my vectra is guddering and loss of power
Vectra juddering and lack of power overtaking
