Thread: GSi rear caliper refurb..
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default GSi rear caliper refurb..
    Hi all, really having problems with one of my rear calipers sticking on after my handbrake has been applied. I have cleaned an freed up the sliders and the hand brake mech and thanks to LIZARD i have replaced the spring, cheers mate
    but still its sticking on is there anyone out there that knows how to sort this problem, im assumeing it needs stripped and redun does anyone know how much this will cost or whats involved? or anyone able to do it for me if i sent it to them as i have never been inside one before.
    thanks for any help, Tim
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Did you take the rubber slides off and clean up the metal?
    Nov 2010
    BRECHIN
    yea john, there was loads of white rock solid corrosion, spent an hour chipping it out lol
    got the slides moving really freely. what bugs me is the footbrake works fine its just the handbrake. if i pull it up say 2 clicks it releases so far but not fully. so i am just carefull how hard i put the brake on lol
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    I had same problem bought seal repair kit but never fixed problem so ended up buying new caliper. Think problem is were the caliper slide rubber fits to the caliper. The caliper corrodes and compresses the rubber so stops the slide moving freely , i tried clearing corrosion away worked for about 2-3 months but started sticking again hope this helps
    oops was interrupted whilst replying so bit late
    best thing to do is take caliper off and knock the piston out and clean it all up including the piston
    then put it back together with some oil on the piston and keep working it in and out till its free
    had to do this last week on a quashquai ( 08 plate !!!! calipers didnt las long !!!! )
    Nov 2010
    BRECHIN
    was worried about doing this incase i cant get it back in!
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Just changed mine 2 weeks ago because of the same thing this is the second one i have had to replace this year i thought mine was sticking on when i stopped at lights it would not roll back final straw was when i put it in the garage after a run i could smell the burning after that it was seized on. New one from the dealers £68 + ROT(rip off tax)
    Nov 2010
    BRECHIN
    thats not to bad in price, i assume yours would be the same as mine?
    mine got very very hot 1day and its not been right since
    i just thought with the price of the 314's at the front the rears would be hunners of pounds.
    Edinburgh/outskirts
    Mileage : 38000
    Quote Originally Posted by TimTay View Post
    Might be a slight difference in them im not to sure but price should be about the same
  1. Rear caliper refurb kits? 292mm
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2012, 16:21
  2. Latest stage ~ wheel and caliper refurb
    By Deadman in forum Quick Photo Album
    Last Post: 22nd September 2008, 11:23
