Thread: MOT fail, Co2
    Aug 2011
    Bristol
    Default MOT fail, Co2
    Hi.
    Had my Signum 2.2 direct in with vx for an MOT this week and it failed.
    A few issues I can resolve but 1 I am baffled with.
    It failed on emissions, Co2 only. 2.9 on first fast idle and 3.7 on second fast idle.
    They said they would need to run a diagnostic which would cost me £42.
    Thats steep to tell me what the problem is.
    I phoned kwik fit to compare the price of this and they told me they change the cat when a car fails on Co2.
    Sometimes they use a fuel additive instead and this can clear the problem, the additive costs £20. Will that work?
    What is my best way to get this done quick so I can get the MOT to pass?
    Ashington, Northumberland
    I would change the coolant temperature sensor first. Cheap and if it fixes it, you've saved a packet on the alternatives.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by GARY3306 View Post
    plus a clean air filter and fresh plugs.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    normally oil and filter air filter change will bring down the Co2 a lot all it is, is the unburnt mixture so if the air is clean and the oil is clean you get better mixture
    Quote Originally Posted by AntSSSS View Post
    ......... and fresh plugs.
    He may be on a while trying to change plugs on a 2.2 direct
  1. Mot Fail
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 12:16
  2. Fail MOT
    By rickyf1 in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2011, 18:21
  3. Fail :(
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 19:48
  4. HELP With M.O.T FAIL!
    By corderz in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2011, 09:23
  5. Would you fail an MOT for any of these...
    By ONEMINUTESILENCE in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2011, 17:39
