Thread: light switch
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Default light switch
    by accident I found out that you can push the big light switch
    anyone any idea why???
    Out On A Limb
    It's to help you release the light control unit,should you need to.
    As Pioneer says: You push it in then turn it to the right and releases it from the dashboard.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Thanks, no need to do so, but always nice to know
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    mmmmm interesting feature, must investigate my car
    Yep, headlights off, push dial in, whilst pushing in turn to sidelights position and the switch unit will probably then shoot backwards. Grab the dial and pull forwards to remove the unit. That reveals the last Torx screw that you need to remove to take out the trim under the steering wheel.
    Feb 2006
    Vehicle : Audi
    Trim : A5
    curious to know why youd want to!
    Want to what?, remove the trim under the steering wheel?
    Well, so far..... wire in a GPS cradle and PDA cradle and run the wiring and tubing for my boost gauge.
    You also need to remove that trim to then remove the centre console surround (the bit to the left of your feet) - again, to run wires etc. for different mods.
    Feb 2006
    Vehicle : Audi
    Trim : A5
    fair enough , you win! ya gadget freak!
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    As an update for those with Automatic lighting you should ensure the light switch is set to 'Auto' before pushing in and turning about half a setting (ie half way to Off) to the right.
    Dave
  1. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  2. Light switch
    By Mopar Man in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2011, 01:33
  3. Light Switch
    By calbert07 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2010, 23:29
  4. Light switch
    By ed taylor in forum General Chat
    Last Post: 22nd September 2006, 04:18
