Results 1 to 10 of 11
Thread: If your window regulator ever breaks , please don't complain about fixing it until you read this !!
    Regular Member poves's Avatar
    lancashire
    Default If your window regulator ever breaks , please don't complain about fixing it until you read this !!
    Had a problem with the a3 , the window would rise a few inches then drop down.
    I stripped the door down , and replaced the offending broken cable guides .
    This is how it went
    Sodding Typical on Sea
    eep!!!!!!!
    spoons
    Guest
    All I see is a broken car ?
    lancashire
    Quote Originally Posted by spoons View Post
    It does look broken Can't believe the stripdown to change 2 plastic clips .
    Aug 2010
    whitley bay
    ah not too bad once youve done a couple lol - common fault used to go all the time - did you get a price for a new mech - not cheap!!!! its actually quite a good idea as the whole frame and glass comes out as one after removing a few bolts
    lancashire
    It worries me to think of the cost of a new mechanism + a few hours labour at audi rates , there is not gonna be much change from £250-£300 I reckon .
    Cost me a grand total of £6.22 for 2 clips / retainers and 2 hours of my time fitting them .
    Regular Member aps's Avatar
    cheshire
    Vehicle : Vectra C Sri CDti 150 (satnav)
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    That brings back memories .... the Golf mk4 has the same issues & VW sell an upgrade kit where the clips are alloy .. £25ish if i remember including cables .
    I had both mine go & autoglass came and did the upgrade for £30 !
    Total investment £55 !
    But there is a long standing thing with VAG that they don't see it as a "recall" even though the replacement is now alloy !!!!
    cheers
    lancashire
    Quote Originally Posted by aps View Post
    cheers
    Tbh - I have actually repaired a golf mkiv a while back , the glass had frozen in the frame , guy sent window down , the mechanism snapped and dropped in the door , and the glass fell in the door when it thawed out lol.
    The kit is about £30 from vw iirc - the panel comes off easy enough , then there is an inner membrane ( steel skin ) held on by a load of 10mm bolts , then the reg comes away from the door in one , that's a bit of a bad job aswell , autoglass must be bananas to do it for that price.
    Jan 2010
    glasgow
    same sort of clips on the meganes to and therea pain in the bum is the bottom impact bar got a kink in it towards where the door hinge is?
    May 2011
    Eastbourne
    cheers
    My Mk4 Golf went also, bought the kit with alloy clips off ebay, and found a good guide on the internet that showed very clearly how to change them over.
  1. Window regulator is same or different ?
    By SandyGBR in forum Bodywork & Interior
    Last Post: 21st September 2011, 12:03
  2. Window Regulator
    By manimal in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2010, 14:32
  3. Window regulator?
    By dh.dti in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2009, 12:52
  4. OSF WIndow regulator
    By addyboy1982 in forum Parts for sale
    Last Post: 6th June 2009, 13:40
