Originally Posted by
TonyP2020
The CIM is the module in the steering column that the stalks plug into.
I Used Op-com:
Go into the
BODY then
CIM (Steering Column Module) then
PROGRAMMING then
PROGRAM VARIANT CONFIGURATION then
enter your Immobiliser Code then
find Program Code Index
(I found that I had 2 choices) of
Program Code Index, 007 (No BC) and 008 (BC), then
push
PROGRAM CODE INDEX 008 then
check all the settings are correct (Including Check Control Enabled), check for the BC/wiper stalk (it was the last item on mine), then push PROGRAM.
After a few seconds it should say "Programming Sucessfull"
Power of the ignition for a minute or so, switch back on and check to see if it has worked.
