Thread: Hybrid Turbo question
    Liverpool
    Default Hybrid Turbo question
    Now i am coming to the end of the list of what i want to do to my car, and after a few bits to do cosmetically i want to do a little to engine.
    I am interested in a hybrid turbo, however i do have a few q's which i hope someone can help (more than likely nutron!)
    1. if i was to buy myself a 2nd hand turbo to be upgraded, does it have to be fully functional? i.e if i buy one that requires new bearings for example, would turbo technics replace these as part of the hybrid process?
    2. Once fitted will it have to be tech2'd to the car?
    3. Will anything else have to be upgraded like the intercooler (which i would probably do anyway)
    4. would i be better off ditching the dtuk box once its on?
    This wouldnt be happening for about 6 months anyway, but i want to start putting some dosh away to get it done
    Any help would be great
    Paul
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The Turbo requires no matching to the car (Tech2) as there is nothing electrical on it.
    Bearing replacement would be done as standard when upgrading but if the turbo is damage then it might be unusable.
    The ones I am flogging are £500 with a 52mm compressor. I recomend running no more than 28psi as the MAP sensor tops out at about 29psi and then you could have issues with uncontrolled overboost.
    Sep 2011
    MILTON KEYNES
    Quote Originally Posted by nutron View Post
    How do you set it to 28psi max?
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    With a boost controller I'd imagine
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    is there any thing like this available for the 2.2 dti
    Regular Member Innes's Avatar
    Plymouth
    I think the DTI boost sensor is a little sensitive but id be interested to know if it could be done to a DTI.
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    You would either need a remap it set it up or a boost gauge and a tuning box that adjusts boost too. If you do nothing but fit the Hybrid turbo, it will run standard boost.
    The 2.2 DTI has a GT1849 and could also be upgraded but I do not know what your MAP sensor range is (I would have thought the same still).
    Liverpool
    cheers for the advice, i best get saving!!
    i am only running a dtuk box at the moment, ill either have to swap/sell it for a crd-t, or get rid all together and get a remap
    ill probably also upgrade intercooler as a precaution
    cheers again nutron
    Ashington, Northumberland
    As Nutron says, just fitting a hybrid turbo without doing anything else will return very little gains, if any at all really. Hybrids come into their own with a remap, engine rework, better induction etc.
  1. Hybrid Turbo
    By toughmat in forum Diesel Engine related
    Last Post: 1st May 2013, 17:16
  2. Hybrid turbo here we come!
    By Telly Addict in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2012, 21:52
  3. For Sale: 2.0t hybrid turbo
    By sberrow in forum Parts for sale
    Last Post: 7th May 2012, 15:30
  4. Hybrid turbo
    By R2XPT in forum Diesel Engine related
    Last Post: 28th January 2012, 21:05
  5. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
vectra c 2.2 dti hybrid turbo
vectra 2.2 sri dti turbo upgrade
zafira dti hybrid turbo
vectra 2.2 dti turbo upgrade
vectra c y22dtr hybrid turbo
