Thread: It's dead!!
    Regular Member Ben_'s Avatar
    Audiville, WM
    Default It's dead!!
    Fitted new stereo Thursday went to turn key this morning.....batteries dead!! What have I done wrong or is it because I was in car for about 2 hours interior light and stereo on without car running??? Hoping it's the lata as can't think what would have gone wrong on wiring....
    Car just sat yesterday not started at all.
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Did you remove your faceplate from the stereo? The way the aftermarkets are wired means they're always on a Permanent live...
    Audiville, WM
    Doesn't have a removable faceplate, and can only be turned on when ignition I'd on??
    May 2011
    bispham, blackpool
    push start car or jump it let it run for a while or drive it for half hour to charge it back up if after all that its still dead your battery or alternator is broke if its charged up and same again in moring its flat then the sterio is wired wrong
    Regular Member paddyvectra's Avatar
    Jul 2011
    Carterton, but.....I walk a lonely road the only road i have ever known
    if ya perms always on ya could always relay it through a switch thats easy enough to install
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Need swap red an yellow wire around.
    Could be that you just drained batt from having stereo on. Or it could have been that stereo was drawing power.
    Have you got a multimeter?
  1. Dead car
    By vectra 120 in forum Engine & Drivetrain
    Last Post: 5th February 2013, 14:44
  2. is my cat dead?
    By victorM in forum Engine & Drivetrain
    Last Post: 29th September 2011, 21:34
  3. DTI Dead!
    By si_hoss in forum Engine & Drivetrain
    Last Post: 26th September 2011, 11:11
  4. Dead PC - HELP
    By Leemarksmith in forum General Chat
    Last Post: 1st January 2011, 23:52
  5. Very dead car....
    By danBoy in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2010, 13:08
