Results 1 to 10 of 11
Thread: Heater air con fan and all interior lights failed
    Default Heater air con fan and all interior lights failed
    Just driven the car back tonight and the heater, air con, blower and all the interior lights have failed. I cleaned both the scuttle trays a couple of days ago as I had wet floors and checked the posts here and followed the advice. Is this likely to be connected to poor scuttle management? What do I do now?
    wirral
    32 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Check fuses
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Sounds like the issue Paddy had at Trax which turned out to be the battery overload fuse.
    Yes the battery overload fuse had indeed popped, but as soon as I replaced it it popped again....any ideas?
    Ely, Cambridgeshire
    58 Post(s)
    Year : 2010
    Not got a bit of foil folded up in your glovebox light to make your new LED bulbs fit have you? (sorry Paddy, couldn't resist)
    In all seriousness though, no, not really, but check a few things, looking particularly for shorts, internal bulbs and connections, heater/blower resistor pack etc
    Basically, something's shorting directly to earth that shouldn't be somewhere.
    Ok, the battery overload fuse pops when the ignition is not even on, could it be the light module behind the dash? Could water from the blocked scuttle got in there? even though it was working ok pre and post scuttle clean? It seems everything else that is not working needs the ignition on to work except the interior and dashboard lighting.
    Admin plasma's Avatar
    On the Forum
    221 Post(s)
    Engine : 150
    Mileage : 74000
    Remove the glovebox and disconnect the glovebox light connection...
    Remove the heater control panel and disconnect the two multiplugs,
    remove over head console and disconnect the interior lights
    also do the same to the boot light... All on the same fuse i believe
    try again and see what happens... If you've got a multimeter you can check the fuse holder to ground first to see if the short has been removed...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    well I've got RAC coming out now..... my patience with cars is not great....
    Thumbs up
    Ok folks, it was fuse F12, and the short was from a broken boot light wedged against the body....simples...thanks for all your help.
    Ely, Cambridgeshire
    58 Post(s)
    Year : 2010
    Glad you got it sorted
  1. Interior heater.
    By xoborp in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2012, 10:01
  2. DIY Map lights, Interior lights Off button console?
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 10:35
  3. Lights failed on instrument panel
    By Chuda in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2012, 01:20
  4. Sidelights, Number Plate Lights, and Interior Lights
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 07:34
  5. Vectra 2005 2.2 SRI Direct Interior Fan/Demistor failed
    By sanderstrog in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2010, 20:35
vectra c interer lights heater not working
vectrs c side lights on fan stops working
