Thread: possible hid fault, what could it be?
    newport
    Default possible hid fault, what could it be?
    fitted a hid kit to the vectra c today (with the canbus cancelers)
    all went in fine and tested with no issues. however started the car up again and hour or so later and the bulb warning message popped up on the dash. went out and had a look and the drivers side light was on but dim compared to the passenger side. checked all the wiring, started it up again and it was fine. tested again, earlier and same problem again. turn engine off and back on and its worksing fine again. going to strip it all out again tomorrow and refit, just incase its a loose/bad connection somewhere.
    could the bulb be at fault or the ballast if its not the wiring?
    WGAF#5
    Probably the ballast mate ... swap it to the other bulb and give it a test
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I'd say sounds like faulty ballast
    newport
    cheers, will get onto the seller, and there was me thinking after i fitted them, 'that was easy' lol
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Check the big red connector and the smaller black ones. Sometimes the pins/blades inside the plugs can become dislodged/bent and can move causing this fault.
    newport
    cheers,
    since my last post i have changed the ballasts with each other, and 'touch wood' its been fine since, just hoping it was a loose connection or like you say a bent/dislodged pin, only time will tell
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Just keep an eye out mate I had dramas on 1 of my ballasts an it was condensation on circuit board
    newport
    problems back, but on the other side now, so can only assume its the ballast.
    contacted seller and awaiting response
  1. Not sure if this a fault or not.............
    By carperjake in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 20:39
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. ABS fault...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2011, 03:05
  4. Another Fault
    By khile in forum Vectra C / Signum Troubleshooting
    Last Post: 20th March 2010, 18:57
  5. swirl valve fault or egr valve fault
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 09:04
