Thread: pin hole water leak in engine block !!!
    Runcorn
    Default pin hole water leak in engine block !!!
    vaux vec 1.9cdti 150 , had a leak , we thought it was the radiator but after fitting new one , the leak was still there then after further investigation discovered small hole just below the manifold on the front side of the engine block ( basically squirts water out like a water balloon would do with a small hole in ) , any ideas what could be done for a temp or permant fix without changing the whole engine !!!
    Jun 2011
    manchester uk
    I dont know if the engine block is aluminium or cast iron, cast iron would be easier to fix as you could sand the area clean and get a exhaust centre to put a spot weld on it, shouldnt cost more than a tenner, there are aluminium welders out there but i believe there are not many places that do it??
    just a thought!
    Engine : 1.9 CDTi
    Better of taking a picture as the waterways are not that close to the edge of the block so it's unlikey for it to have rusted that much.
    Any other items above it it could be leading from?
    Regular Member poves's Avatar
    lancashire
    Sounds like it could be a core plug ? easy fix if it is , these are designed to push out of the block if the engine freezes , rather than cracking the block .
    Is there a circular cutout / indentation to the area from where the leak is.
    The last ones I replaced were about the size of a 2p coin.
    Regular Member PORKBALLS29's Avatar
    Epping
    Quote Originally Posted by poves View Post
    Had to replace a core plug on my old MG Maestro cost me £14.00 to have it done at the garage. But that was over 12 years ago now lol.
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    must back up Poves,it would be unlikely for a water way to rot but core plugs do
    Runcorn
    mechanic is tryin the weld method !!! not core plug !! even spoke to vaux mechanic never known it !!!!
  1. engine block painting
    By Caveman_nige in forum Styling
    Last Post: 6th May 2012, 07:17
  2. lifting an engine block by hand
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 10:34
  3. engine block light on????
    By rab,gsi in forum Engine & Drivetrain
    Last Post: 14th December 2011, 13:43
  4. Engine block 'idiot light' ON!!!!!
    By cb500t in forum Engine & Drivetrain
    Last Post: 30th November 2011, 15:41
  5. Where is VIN on engine block
    By manimal in forum Engine & Drivetrain
    Last Post: 25th October 2010, 12:44
how to change core plugs on vauxhall vectra 1.9cdti
vauxhall vectra estate water leaking from block
replacing vectra c core plugs
https:www.vectra-c.comforumshowthread.php147784-pin-hole-water-leak-in-engine-block-!!!
