Thread: clio dci
    Regular Member tazdog03's Avatar
    May 2011
    barnoldswick
    Default clio dci
    can anyone help been working on a renault 1.5 dci timming belt snapped and bent valves took head off and replaced valves put it back together and it tries to start but wont tick over or run contantly any ides would be appriciatd
    Regular Member stuartbat's Avatar
    May 2008
    shropshire
    K maybe its a timing issue. Valves all lapped in? I had this on my nieces astra when head gasket was done turned out to be the cranks sensor was ******ed
    May 2011
    barnoldswick
    all timming spot on and vavles ground in if i spray easy start in it tries to run then stops cant understand it doing my head in
    May 2008
    shropshire
    if it trying to start then it sounds like u have no compression issues must be something electronic not letting it start?
    Not sure on them engines tbh its not a fuel problem ?
    May 2011
    barnoldswick
    there seems to be plenty of compression but will check that im woundering if its an injector fault maybe
    May 2008
    shropshire
    As its a diesel dont you have to bleed the fuel back through ?
    May 2011
    barnoldswick
    yeah its diesel and done that pump it through
    May 2011
    barnoldswick
    well got it to run with easy start then stops again wont run under its own fuel if anyone cant help im all out of ideas fuel getting to injectors heater plug light goes out as it should cant c anything amiss anywhere help please
    Engine : 1.9 CDTi
    Did you need to time the diesel pump back up?
    May 2011
    barnoldswick
    no just tried the easy start first
  1. GSi vs clio 172/182
    By Chuddy in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2010, 23:51
  2. help! Clio 1.2 16v
    By kev bux in forum Engine & Drivetrain
    Last Post: 8th October 2009, 15:43
  3. renult clio help
    By mattolly86 in forum General Chat
    Last Post: 4th February 2009, 16:52
  4. Clio
    By jonesy_ni in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2007, 00:37
  5. Anyone want a Clio
    By AJA in forum General Chat
    Last Post: 22nd May 2007, 09:16
