Thread: Help with uneven tyre ware
    gwent
    confused Help with uneven tyre ware
    Hi I've just notice that my left front tyre has uneven wear on it's the inside edge that's wearing the right hand side is ok do you think that the tracking could be out. I have not hit anything with the wheel or potholes so I dont know what the problem could be
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    tracking generally wears both tyres
    If this same tyre has been on the rear, then that suggests the rear suspension component has worn
    It is very common to have uneven wear on front tyres if the toe on one side is incorrect, this then wears out the tyre on the opposite side
    So first thing is to have the entire suspension examined for worn components
    If this shows no issues, then a full four wheel alignment can be carried out
    5 Post(s)
    Quote Originally Posted by cossiejay View Post
    Odd, whenever I've had the tracking out (on the front), only one tyre has abnormally worn.
    As above, if the toe is incorrect on one side then there will be wear on one side
    As mentioned previously this is an indication the cheap method of adjustment was used and simply adjusted one side to obtain the correct toe, where as both sides should be adjusted (the difference between front wheel alignment and full four wheel alignment)
    Equally, if you drive around a lot of roundabouts then there is more likely to be wear on the nearside front tyre (on a front wheel drive only car)
    gwent
    I have never had a problem before but the tyres don't last that long anyway 2years is about as i get with 235/35/19 i just ordered a pair for the front now neuton nt5000 for £183.63 so when they get fitted i will have the tracking checked
    Quote Originally Posted by wayne10244 View Post
    Don't have just the tracking done, acceptable if the alignment was carried out recently and suspension is known to be in good condition (MoT recent)
    Swap the rears to the front, and have the new tyres fitted to the rear
    At the same time have the entire suspension examined
    Once completed have a full four wheel alignment carried out (Hunters equipment)
  1. Uneven tyre wear part 2
    By Celes in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2011, 11:53
  2. Uneven Tyre Wear
    By sri/cdti/150 in forum Handling & Braking
    Last Post: 19th February 2011, 11:33
  3. REALLY uneven tyre wear
    Last Post: 21st November 2010, 23:25
  4. Uneven tyre wear
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 15:16
  5. Uneven Tyre wear
    By Manni2375 in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2007, 15:19
