Results 1 to 10 of 30
Thread: Cyclists.... how to stop your nuts hurting?
    Regular Member bigdave1701's Avatar
    York
    Default Cyclists.... how to stop your nuts hurting?
    I used to be a keen cyclist and never had a problem with ball ache (was riding BMX and dual slalom so seat hight want important). After 4 years of getting fat, I've pinched my dads old mountain bike and am cycling to work as often as possible. Problem is with the seat at the correct height, it squashes my balls! I've tried tilting the seat down a few degrees and it helps but I find I'm slipping off the front of the seat all the time! Anyone able to offer some pearls of wisdom on this one?
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Padding. No way around it! I bought a gel padded seat cover and it's helped a bit.
    Regular Member jimmywhu's Avatar
    Sep 2011
    essex
    lol i have that prob big nuts small seat? what i did was buy a half decent seat whent to the bike shop got a decent seat told him what the prob was and he soon decided to tell me to buy bike shorts with a sort of form bit around ur nuts n bolts worked great no ball pain wallop ride pain free
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    what a manly thread lol
    York
    cheers. I'm saving for a new bike as this one feels too small in every way so a seat cover as a temporary measure will have to do.
    gwent
    Padded shorts are the best padded saddle are a waste of time the more you ride the bike the less you will feel sore give just over a week and you should be ok if not you need a different saddle this is the hard bit to get wright there's so many different styles of saddle it took me 3 different saddle to get wright and £275 if I was you I would try a charge spoon saddle they cost about £20 to 25
    Sep 2011
    essex
    the shorts worked for me very good and pain free but wayne is right the more u ride the better you balls feel lol
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Padded shorts are the place to start. You can get inserts that will go in most shorts, and you can get baggy shorts that look standard but with padding (so you dont have to have tight lycra). As mentioned saddles to make a difference. Have a look at the charge spoon saddle for a cheap comfortable saddle. The best saddles are brooks, but they require bedding in. I know will only use brooks saddles on the bikes I use for long distance rides.
    Sorry just realise Ive written pretty much the same as Wayne!
    brumie brum brum
    As has been mentioned a good set of padded shorts that will also hold your nuts in place.
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    That and taking a bit of pressure of the man jewels
  1. Bumhole hurting very muchly!!!!!
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 13:58
  2. Replies: 2
    Last Post: 11th June 2012, 10:07
  3. I know alot of you dont like cyclists
    By Ziggy in forum The 'Off Topic' room
    Last Post: 10th June 2011, 15:34
  4. Cyclists look ..........
    By FIL 4822 in forum General Chat
    Last Post: 10th May 2008, 16:51
  5. FAO-cyclists
    By pyro_maniac in forum General Chat
    Last Post: 8th April 2008, 15:39
