Thread: VXR Honeycomb stuff
    Regular Member andythilo's Avatar
    Oct 2006
    Saffron Walden
    Default VXR Honeycomb stuff
    Hi
    As I am already starting to think of changes to make to my forthcoming SRi Nav XP veccy, I would like to replace the front bumper and grill inserts with the honeycomb style stuff that the VXR has.
    Is this possible?, the grille looks the same, but i'm not sure about the bumper and fog surrounds.
    Anyone know the answer to this?
    Andy
    Oct 2006
    Saffron Walden
    Blimey, no one knows the answer to this?, cmon dont be shy, speak up
    spoons
    Guest
    The only bit of info I have on the grill bit, is when Vauxhall Dealer painted my 'V' grill they noted how BIG the plastic slats were that sit behind the 'V' grill. Apparently they go half way down the inside of the bumper....??
    Dont know anything at all about the honeycombed VXR thingies.... dont think anyone has done that modification yet !!
    You could be the first and Guru on the subject once completed !!
    Oct 2006
    Saffron Walden
    I do like the honeycomb, looks much nicer than the standard SRi stuff :
    Question is, are the fogs and front bumper holes the same size??
    spoons
    Guest
    Quote Originally Posted by andythilo
    Answer: No, the VXR fog lights are a completely different shape/size and will not fit on the facelift SRi bumper. Neither will the Signum chrome fog surrounds. The Signum shape is correct but the fog light surrounds are 'heat bonded' onto the bumper. The lugs that are used are in a completely different position to the Vectra. This means that they also cannot be used !! - thats what I have been reliably told anyhow.. you may want to double check the signum fog surrounds yourself first...
    Pain in the backside, as I wanted chrome surrounds on my SRi
    Oct 2006
    Saffron Walden
    Oh well i'm not gonna start putting on a new bumper and fogs just to have the honeycomb. Might have to do the painted V-grill though, that looks really nice. That and a nice VXRD badge on the back
    I notice you took the badge off the back of yours Spoons, how hard was that?, is just a hairdryer job?
    spoons
    Guest
    Yep, cut & blow dry should do it....
    I used an old plastic card (like a credit card) to slide beneath the badge and cut through the sticky pad. Whatever bits of sticky pad were left, I used car wax to rub it off with.. Bit of hard work and Tar Remover would of been easier...
    Should leave your chrome strip nice and shiney !!!!
    Call Rob on 01922 645 938 for your VXRD badge, but remember to allow at least a week for manufacturing it
    Oct 2006
    Saffron Walden
    Already been in contact with Rob
    spoons
    Guest
    Nice one.... dont forget the pictures when its all done
  1. Honeycomb wheels
    By R-man in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2012, 17:12
  2. Vxr Honeycomb grill
    By boodoo warrior in forum Styling
    Last Post: 28th May 2011, 14:40
  3. Green Stuff or Red Stuff Pads?
    By redraptor_141 in forum Handling & Braking
    Last Post: 21st August 2009, 18:44
