Thread: Problems :((
    Regular Member tuga32's Avatar
    Dec 2010
    Harlow
    Default Problems :((
    Hello all,
    I am having a few problems with my Veccy,
    Low performance,
    Flat Spots,
    Increased MPG,
    I have changed the EGR and cleaned the Boost sensor,
    What else can be wrong guys!!!
    Now I got the tool light on the dash.
    Any ideas?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Noticed on your profile you have a CDTi SRi 150?
    Check the swirl bar is still attached, and check the turbo / vac pipes for spilts
    Dec 2010
    Harlow
    Quote Originally Posted by tony-1977 View Post
    Is there a thread on how to check the swirl bar?
    Will be checking as many pipes as possible,
    The wistle on the turbo is still there but on a scale from 1 to 10 being 10 the worst I would give it a 7 if so (
    Very down at the mo with many things, such as work the new house building and other more private issues and there comes my Veccy the only thing that puts a smile to my face this days and Boooom, sadness all over (
    Maybe I am just having a bad day, hey oh.. .
    Dec 2010
    Harlow
    And thanks Tony-1977, much appreciated,
    north east
    ^ that,
    and get a mutimeter out and check your alternator output with the engine running your looking for 13 - 14.5 V
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    take the plastic engine cover off
    attatched to the top back of the engne is the inlet manifold.
    if you look down in between the manifold & the engine you will see the bar.
    Hopefuly itl be attacthed
    Bristol
    The most common problem with loss of power is split vacuum pipes on the front of the engine the runbber elbows split.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Unlucky mate.
    As others have said, check the swirl valves. Look down the back of the engine and you'll see the inlet manifold. You'll see the bar there too. It should be attached but if it's lose or just flapping around not attached to anything, it will be time for a new inlet manifold.
    Hope you get it sorted dude.
    Dec 2010
    Harlow
    Any pics or threads on what I should be looking at guys?
    Thanks for the comments,
    Looks like a busy morning before work tomorrow (
    Dec 2010
    Harlow
    Hello all,
    Right,
    Pipes all checked and no cuts or anything diferent than normal,
    Swirl Bar checked and moving freely and tbh almost clean, no much soot,
    Will see how it behaves on route to work later on and will be crossing my fingers that all is back to normal )
    Thank you all,
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
