Thread: problems after cleaning egr valve
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Default problems after cleaning egr valve
    I decided to clean my egr today as I haven't done it for over 6 months.
    After fitting back to the car it was spluttering, smoking & wouldn't even rev
    My heart nearly jumped out of my throat lol.
    There was also no engine management or fault code showing.
    Took it all appart again & pushed the egr spring to the closed posistion.
    It seems to be ok now. And still no fault codes.
    Does this mean my egr is stuck closed? As I'm not sure wether to replace it or not.
    Sep 2009
    swansea
    Trim : Club
    bump
    can anyone shed any light on this?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    If you had to push it to the closed position then that means it was jammed open. They don't produce fault codes when jammed open. They will generate a fault code when jammed shut however as the ECU will detect low EGR gas flow.
    Sounds like it was jammed open to me. That's what they normally do if they jam open - hamper performance badly. Conversely if they are jammed shut the will throw a fault code with the emissions light on the dash illuminated - but actually drive better at lower rpms.
    Insignia VX-Line Nav CDTI 170.
    Sep 2009
    swansea
    Trim : Club
    Sounds like it was jammed open to me. That's what they normally do if they jam open - hamper performance badly. Conversely if they are jammed shut the will throw a fault code with the emissions light on the dash illuminated - but actually drive better at lower rpms.[/QUOTE]
    badly isnt the word it would barely run & wouldnt rev.
    i thought i had seriously broke it.
    I didnt even try driving it, dont think it was driveable lol
    Ive driven it for 5 miles ish 2night & gave it a good thrashing.
    no light has come on as of yet.
    does this mean the egr is still functioning correctly?
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by monty2000 View Post
    badly isnt the word it would barely run & wouldnt rev i didnt even try driving it.
    does this mean the egr is still functioning correctly?[/QUOTE]
    Probably or is mroe so in the closed position - ie enough to keep the light off but enough that the runs.
    I have mine blanked off as the valve was a pain in the arse on my motor.
    Sep 2009
    swansea
    Trim : Club
    still running ok (Fingers Crossed) seems like moving the valve seems to have freed it up again.
    Wont be cleaning it again lol absolutley crapped myself
    If it aint broke dont try & fix it
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    I would say it still worth cleaning it out every now and again to avoid any other problems.
    I cleaned mine yesterday,didnt need to but i thoguht i would before the bad weather sets in.It was too dirty but still glad i did it.
  1. Cleaning EGR Valve?
    By cornishpirate in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2014, 12:48
  2. Cleaning of EGR valve
    By inverkip1 in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2009, 20:01
  3. Cleaning EGR valve ?
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 8th January 2008, 09:33
