Thread: car going into limp mode 1.9 150
    Aug 2011
    Devon
    Default car going into limp mode 1.9 150
    Right this is gonna sound random so i will do my best to explain it. basically since i bought the car i have had problems with it. now the injectors are sorted the car keeps loosing power sometimes the emission light comes on sometimes it doesnt there's no set speed/rev range where this happens. but its as if the turbo shuts down, the only reason i think the possibility its the turbo is i have had the same with my 1.7 corsa and that was the turbo knackered. anyone had similar problems??
    am i on the right line and if so is replacing the turbo a relatively straight forward job, if so i want to try it for my self, the intercooler was replaced about 6 months ago if that makes a difference
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Mate- before you change any hardware - get the codes read. otherwise you could be changing stuff like turbo's etc for lots of £££ when not needed.
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I would look at the EGR Valve after 1st checking the codes. Check EGR , 3rd Injector, Inlet Manifold and DPF if fitted.
    Aug 2011
    Devon
    thanks guys will get it read in the next few weeks im in no rush as going to start treatment soon again 3rd injector is fine (all 4 are) im pretty sure this one doesnt have a DPF as it kicks out smoke all the time under load. will pull off the EGR again friday and give it a quick clean out.
    Paul
    Aug 2011
    Devon
    i have now blanked off the EGR and no more problems
    Feb 2011
    Telford Shropshire
    Just check if your car is fitted with dpf filter (0.5 on door sticker) if so driving with blanked egr will kill it very soon. It did on mine so I ended up removing it as well
    Aug 2011
    Norway
    I had the same issue with mine, the problem turned out to be broken boost pipes. Check yours for splits around the bends.
  1. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  4. Limp mode
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
