Thread: Auto light switch
    Full Member
    Bristol
    Default Auto light switch
    Has anyone fitted an auto switch in place of a standard swich , if so do I have do do any wiring changes. Mine is a Vevtra 56 07 model SRi .
    Regular Member R2XPT's Avatar
    Scotland
    Quote Originally Posted by sb1uk View Post
    Yes I done mines Saturday, if u already have the window sensor then I should be a case of new switch and tech 2
    Full Member
    Bristol
    Default auto
    Thanks mate did you have to get the same indent on the switch.
    Scotland
    What u mean? Do u have the sensor fitted?
    Full Member
    Bristol
    On the back off the switch the is a 2 digit on back of switch and how do I check to see if I have sensor.
    Scotland
    I bought the whole xenon auto switch, plug and play, if there is a sensor below ur rear view mirror then u will have it
    Full Member
    Bristol
    Quote Originally Posted by R2XPT View Post
    There is no sensor there. just standard mirror. My 04 elite has it.
    Scotland
    U might have the roof loom if u remove ur front inside alarm sensors just In front of the mirror, have a look there and if u find a small black plug with ribbon loom, pull it out far and if it says rainsensor then u have the loom fitted, all u will need is windscreen to suit sensor, auto switch and sensor and u will autolights and autowipers
    Full Member
    Bristol
    ok I will have a look. I might sell it soon and get and get a newer elite. Thanks mate for you help.
    Scotland
    No probs mate
  1. auto headlight switch AND daytime running light
    By nipmads in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2012, 08:18
  2. Need help activating auto light switch
    By john norris in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 20:53
  3. Auto light switch
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 21:28
  4. Can you measure your auto light switch?
    By yysnet in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 20:45
