Thread: limp home mode
    South London
    Default limp home mode
    Hi I have just got home from a fast return journey, total mileage 140miles, from around the M25. Faultless journey until I came off the M25 at J8. About 10 minutes later the car went into limp home mode with the spanner light on and the car would not go over 20 m.p.h.
    Stopped the car, turned the ignition off then on again and continued home as normal, with no problem.
    Read the engine fault codes which showed:-
    P0234-5A Boost pressure control circuit negative deviation.
    Where would you think I should look to fix the problem?
    My car is a 2004 2.2DTI Vectra.
    Thanks for any help.
    WGAF#5
    Go on ..... Showed .....
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Go on Moved !!! please post in correct section in future
    Irmscher Insignia CDTI 130
    South London
    home mode
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Franka
    po234 is your boost pressure sensor , what usually happens here is that they become covered in crud from the inlet manifold itself what you ned to do is remove it and give a clean with some carburettor cleaner or some petrol .
    thats the easy part , now if the boost sensor is cruded up then its a fair bet that the manifold itself is along with the egr , so find yourself some time and strip and clean all these parts you will find its worth it
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Merged !!
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Probablyneeds the boost sensor cleaning, also check all the small rubber vacumm hoses to see if any have come off/split.
    South London
    Hi
    removed the throtle body,egr valve and boost pressure sensor this morning.
    All were clean with no crud build up. Not suprising as it was only 2 years ago that the boost sensor was replaced and the EGR valve and throtle body were cleaned.
    I have checked all of the vacuum pipes and they all look fine. Also checked all the boost pressure pipes which also look okay.
    Bit worried about not finding anything wrong.
    What do you think?
    Regular Member Innes's Avatar
    Plymouth
    Maybe the turbo actuator rid needs half a turn as it could be over boosting.
  1. limp home mode
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 22nd September 2012, 09:12
  2. Limp Home mode
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 19:43
  3. limp home mode
    By fig in forum Engine & Drivetrain
    Last Post: 20th January 2010, 23:18
  4. CR2 going into limp home mode
    By plasma in forum Diesel Engine related
    Last Post: 17th April 2006, 20:45
P0234-5A Boost Pressure Control Circuit Negative Deviation
