Results 1 to 10 of 27
Thread: Help needed with leak on signum :( (with pics)
    Regular Member Shogun's Avatar
    Aug 2011
    Default Help needed with leak on signum :( (with pics)
    I thought id managed to fix this but clearly not as i just went to my car and its sopping
    I mentioned in another thread and you can see on the pics that the passenger side light has a small crack in it.
    well i discovered the leak and then traced it back to that, however alot of water had already got in,
    i siliconed the gap up and even put a small peice of plastic in and siliconed around that (looks tidy though)
    and thought i was onto a winner, however just been out now and its still getting in!
    so im wondering if anyone has dealt with anything like this before.
    the little access hatch where you get to the light cluster.. jesus well i opened it before and its sopping wet in there and the wires are wet
    my spare tyre area was covered in water too, and as im writing this its bombing it down so please anyone got any ideas ???
    the little light crack is surely not still letting water in, however its weird that it is only on the passenger side where the crack is,
    thanks guys and i really hope someone can shine some light or ill be getting a vectra|! lol
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    My money would be on Aerial base take it off and seal it with silicone and check after a down pour
    Irmscher Insignia CDTI 130
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Have you actually undone the three nuts that hold the light unit in place and checked that it has the foam seal still in place, might be leaking from there
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by bigmac View Post
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi m8
    i had a right puddle in me spare wheel well on me last signum and i checked
    everywere and it wasnt leaking through the rear lamps or anything but it
    kept filling up so i eventually found the problem so here goes-
    the rubber seal around the aperture wasnt pushed on properly so check
    along the top and were it turns and comes down each side and also down
    were the rear lights are,the main leaking was on bends were the seal turns
    so make sure the seal is fully pushed fully against the body,soon as i done
    this i sorted my leak and at the time my car was under warranty which i
    was given a new seal and boot floor carpet etc.
    let us know how you get on
    Aug 2011
    Thanks guys your all the best, ill check all these things
    i just got a feeling it's to fo with the light though becos,
    inside the boot where the access hatch is sopping wet and that's nowhere near the aerial or hose thing, and it's wet near like.. The bottom left hand corner metal ring where you attach the cargo net
    but besides getting a new light I don't know unless like someone said above,
    take the light out and maybe silicon it up??
    Thanks a million guys
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Not saying it's definitely it, but the aerial base is a VERY common problem on the Vecs, the rubber deteriorates, the water gets underneath it and runs down the inside of the roof, down the back pillars and into the boot.
    Very common indeed.
    Aug 2011
    Hmmm I wonder if it could be the aerial, how could I check that.. Just get a new one?
    To be fair I've looked at it and it's a bit knacked, but wouldn't the water be on both sides and not just the side with the cracked light
    Engine : 1.9 CDTi
    Drop thye back of the roof lining and feel the area to see if its wet.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Just changed my aerial base yesterday as it had perished and my boot had water in it. Ok the Signum is different from the Vec but I took the N/S boot lining out and ran the hose over the aerial base and was able to watch the water pour in the NS inner wing area.
  1. Help needed Vectra oil leak
    By tunnafish in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2011, 09:32
  2. Oil leak? Please see my pics!
    By stryker99 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 08:54
  3. oil leak help needed
    By b3kaw in forum Engine & Drivetrain
    Last Post: 15th March 2010, 20:55
  4. help needed on blowers and leak....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 15:02
  5. oil leak help needed
    By ditchp in forum Engine & Drivetrain
    Last Post: 27th September 2007, 07:49
signum rear lights leaking
signum leaking rear lights
