Thread: Vectra 1.9 120 turbo lag
    Jan 2010
    EK
    Default Vectra 1.9 120 turbo lag
    Hi guys I wonder if anybody may know what my main problem could be here. My Vectra is a 1.9 8v 2006 model and is now at 50,000. Well over a year ago the EML light came on and the diagnostic was the EGR valve needed replaced. I didn't bother about it as the car was driving well. During the summer I got the car serviced with MOT and the flexi part of the front pipe had gone so full front pipe was fitted. I still hadn't bothered with the EGR valve however with new front pipe in the car was quieter and still drove well.
    Only about 1000 miles later the turbo started to kick in at around 2500 rpm. This got worse and the engine has became noisy with the turbo kicking in at 3000 rpm. I got the EGR valve replaced, the EML has went off and there is slight improvement with acceleration. When reved hard black smoke comes out the exhaust although it's done this for a few years but got worse. When I rev the car over 4000 rpm the spanner light comes on and the car really struggles with no revs where the turbo would kick in. However if I switch engine off and back on the spanner light is off and it drives the way it has been. I have also noticed the engine is noisy again and sound the same way before I got the front pipe replaced. Could the Cat be blocked or have I got an expensive problem???
    Regular Member Marky's Avatar
    Jun 2006
    North West
    if the spanner light goes off when you restart the car then it was an intermittant fault.
    For the loss in power check your boost pipes for holes. See post #6 in this thread: http://www.vectra-c.com/forum/showthread.php?t=109454
    Jan 2010
    EK
    Well went out this morning and seen a hole on the rubber part of the boost pipe. I decided to put some duck tape round it for just now to trap the air. Your spot on Marky took it a drive and the car was flying turbo kicking in just when it was leaving 1500rpm. Still got the rift which sounds like it's from exhaust and the engine sounds tappety. But what a difference like a new car. Cheers.
    Jun 2006
    North West
    Great news
    Now go to ebay and purchase a metre of new pipe and get it fixed permanantly http://www.ebay.co.uk/itm/4mm-Silico...item45fd23e7d5
    Jan 2010
    EK
    Thanks for your help I will get a new pipe. I knew a hole in the boost pipe would affect the turbo but not as much as it did. Thanks again Marky.
  1. My New Vectra 2.0 Turbo
    By Mark2.2 in forum Quick Photo Album
    Last Post: 1st December 2011, 17:34
  2. vectra turbo
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2010, 19:09
  3. vectra c 2.8 v6 turbo
    By LOCKSTOCK in forum Engine & Drivetrain
    Last Post: 31st July 2008, 19:54
  4. my vectra sri turbo
    By mooney in forum Quick Photo Album
    Last Post: 16th February 2008, 01:28
  5. vectra 100 turbo
    By JATBOY in forum Tuning
    Last Post: 14th September 2006, 22:37
