Thread: help double din kit
    Jul 2011
    UK
    Year : 06
    Default help double din kit
    I fitted double din other day but I didn't use any the screws or plates as I don't no were these go or what they do also some kind of sponges that stick on summit yer the stereo OS in and won't come out unless push behind but its bugging me what to do with these bits
    gwent
    Hi you don't use the sponge as I said before get your head unit and the side plates that in the kit then get the clips that fit in the side plates and slot them in the groves in the side plate adjust them so they a not to far forward and screw the side plate's to the head unit you should use the third hole on the plate fit the cage and just push your head unit in to see how much the front sticks out. If to much move the clips in the side plate's . When you are happy with it slide the cage back out and slide the cage through the surround and push back into the dash and push the tabs on the cage to lock it in place. Now connect the head unit wires up and push the head unit in till you hear a click but make sure that you don't catch any of the wires now to the head on to make sure it's working all that left to do is fit the face plate and that it
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Does this help?
    Jul 2011
    UK
    Year : 06
    Cheers for right up al have a go tomorrow my headunit don't stick out its nicely in place the surround moves slighly and 2 clips on the black surround broke so used sticky silicon pads
  1. Has anyone got one of these jvc double din hu
    By Veccy55 in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2013, 16:19
  2. double din help
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2011, 19:29
  3. How 2 Double the value of your car
    By duncmill in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 20:32
  4. double din
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 22nd September 2008, 08:05
  5. double din
    By stuart bigboy in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 4th June 2008, 12:00
