Thread: Brake light warning message
    Sep 2010
    northamtponshire
    Default Brake light warning message
    Hi guys,
    i have a 57 plate veccy.
    Every now and again i get my brake light warning message on my little display screen and the warning light on the dash lights up.
    Ive checked the bulbs etc and the lights are in full working order. Ive checked the connections and they all seem ok.
    Has anyone else had this issue or got any clues?
    Feb 2011
    Mansfield, Nottinghamshire
    Hi,
    I have also had this problem. I have checked all the bulbs etc and everything works but still keep getting the message up.
    I'm in the same boat as you.
    Hoping someone on here has the solution!
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    double check the rear lights, as when one bulb blows it uses a different one (maybe the fog light i cant remember) as a substitute - check they are both level...
    If it isnt that, then i've no idea.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just change the bulbs and clean the connections from the loom to the light back panel. Odds on its the bulb. Mine did this and the bulbs looked fine, what I couldn't see at the time was the element was moving freely in the bulb, most of the time it was in contact with both poles but now and again it came adrift and tripped the warning message.
    May 2011
    bispham, blackpool
    even if the brake light still works their will be a problem with one of the bulbs i use to get it all the time untill i went to the shop and bought 4 brakelight bulbs and changed the whole lot on both sides now nothing no warnings and didnt cost that much
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Change all four bulbs!
    Sep 2010
    northamtponshire
    cheers for that, ill make it my weekend job
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake light warning message on display
    By don1966 in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2011, 11:15
  3. Brake warning light!
    By lukesignum in forum Suspension, Wheels & Brakes
    Last Post: 1st July 2010, 10:24
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Parking Sensor Warning Light/Message
    By marcdale in forum Troubleshooting
    Last Post: 27th May 2008, 17:13
