Results 1 to 10 of 22
Thread: Front washers trickling!
    Default Front washers trickling!
    My washer jets aren't right! They give a little spurt, then the water just trickles out. I can hear the pump spinning but it sounds like its being strangled! The rear one works fine.
    I've tried flushing the bottle out with a hose, but that didn't work so I have 2 questions:
    Will it be a warranty job?
    What else can I try before removing the bumper etc to get to the bottle and motor?
    Regular Member Harry's Avatar
    Uxbridge, London
    is it all of them Jamie, or just one?
    haveyou checked the hose connections? maybe it's leaking from soemwhere. any telltale puddles under the car?
    it may be a blockage at the bottom of the water bottle, happened to mine, but on the back, cleared itself up after a while, but obviously if its on the front then you want to get that sorted?
    Mark (GSi) will be able to tell you exactly how to get to it
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    Sounds like it's got prostate problems. How did you say the car was ??
    A bit more seriously, it looks like some gunge in the tubes to the front windscreen rather than a motor issue. Better brains than mine can advise on what to do.
    Its all 4... no fluid coming through at all... and no puddles, so there is a blockage somewhere in the system.
    I'm hoping it might be warranty??????????????????
    Uxbridge, London
    from what Mark was telling me when mine was blocked its easy enough to do yourself, you just need to reach under and behind the bumper to get to the bottom of the washer bottle/motor and release a few things and bobs your uncle.
    if you take it to a dealer for a warranty fix you'll only get it back and realise your cruise control doesn't work, the drivers window goes up and down in tune with the music and the rear windscreen wiper is on permanently reminding you of that megane advert and how your car now looks like an over excited puppy!
    Uxbridge, London
    if all else fails, i hear Mr Muscle Sink and Plughole Unblocker works a treat!!
    Jamie..
    if no fluid is getting through at all, then i'd lay good money on it being the stupid filter in the seal around the pump..
    to get it out, look up under the bumper in front of the NSF wheel and find the tank and the pump.. don't need to disconnect anything at all.. just prise the pump straight up and it'll pop out of the tank..WATCH OUT for the tank emptying itself on you!!
    I bet you'll only get a small, slow trickle out of the tank.. what you do then is to prise out the black seal and it'll come out and turn out to be about 1" long..the minute holes on it's end will be covered in a slime.. clean it off under a tap and make sure you get a flow through it..replace the seal and pump, refill the tank and test..
    15 minute job with little dissasembly..
    Regular Member Scalesy's Avatar
    Oct 2006
    Essex
    Quote Originally Posted by Gsi3.2
    Jamie..
    If they ever fit a stupid filter on the drivers door i'll be walking everywhere!
    nice one...LOL
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Quote Originally Posted by Harry
    hahahahah pmsl
    yeah thats wot i`m dreading today if my car is ready but i have
    to be positive with the dealer i`m using now but harry thats a good
    point to mention though.
  1. front washers
    By coooky in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2012, 17:28
  2. No Washers Front Or Rear!
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2011, 18:04
  3. Bulb Failures & Front Washers Not Working
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2010, 21:04
  4. Washers
    By jlock in forum Bodywork & Interior
    Last Post: 8th March 2010, 21:04
  5. Front washers
    By Nicolas in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2010, 19:05
