Results 1 to 10 of 13
Thread: DPF experts required
    milton keynes
    Default DPF experts required
    I am experiencing DPF high pressure issues since I had the car remapped. What I want to know is , if I remove all the internals out of the DPF and have that part mapped out will I experience issues. Or do I have to leave part of the filter inside , so I still have back pressure? The company that mapped the car originally will remove the DPF from the map for another £50 , so no issues there , just want to know what is best to clear it out totally or just partially.
    Thanks.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    If you are having it mapped out then either remove the internals or replace the entire unit with a piece of pipe.
    Full Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    knock it through fully or replace it and map it out mate, there are no downsides and alot of upsides if your having dpf troubles
    the map isnt really due to the backpressure its so the ecu doesnt try a regen which it cant do using large amounts of fuel
    South East Region ARO And Resident Diesel Head
    Owns: 2005 Vectra Life Hatchback 1.9 CDTI 150 Mods: Too Many !!!
    milton keynes
    So if I remove all the internals and then have it mapped out it will be fine?
    Nov 2010
    sittingbourne,kent
    Mileage : 166000
    yepo not a problem, i think several other members have done it, if its not there and the ecu dont know anything about what a dpf is lol then all is ok
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Ian at MPG now do DPF jobs and he removes then with software which is basically a remap and then you can gut or remove the DPF itself and replace with a straight through pipe. Ian also says its quicker and easier to actually remove the DPF rather than knock its guts out. Its my next modd for sure
    Regular Member rockonoli1's Avatar
    Telford
    Do you have to have DPF mapped out or can you just thrash the middle out
    May 2007
    WINSFORD
    So I have been told to avoid errors etc, if the ECU has no trace of DPF on it then no DPF issues will happen
    Telford
    If there is no insides the DPF pressure sensor surely would get the same readings so in theory DPF "will never need regenerating"
    May 2007
    WINSFORD
    Other factors are there to but I am not sure. 1 example is my Remap makes the DPF do a regen every 1000mls so that would be a problem and apparantly you can make your DPF regen by driving at a constant high rpm for a few miles like on a motorway so again another problem. Try it your way and report back as you might be right but I think you will have issues
  1. Any electronics experts?
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2012, 21:13
  2. a bit of help from the experts:)
    By macs_silviu in forum Bodywork & Interior
    Last Post: 9th July 2012, 22:41
  3. Looking for experts
    By Rebellion8878 in forum South Central (RO - Harrysdad, ARO - matty2fatty)
    Last Post: 4th March 2011, 12:47
  4. Stereo experts only lol
    By Gavin2.6 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2010, 12:13
  5. Photoshop experts.
    By Ste in forum Photoshop section
    Last Post: 30th July 2006, 23:04
