Results 1 to 10 of 14
Thread: Knocking from passenger side - drop links?
    Apr 2011
    Barnsley, Sth Yorks
    Default Knocking from passenger side - drop links?
    Hi guys
    Got some knowkcing when going over uneven surfaces from the passenger side - looking around here it seems like its the drop links. Can anyone recommend anywhere to buy from and also what else might be worth changing at the same time? Anyone fancy fitting them for me???
    These any good:
    http://www.vauxhall-car-parts.co.uk/...tml#a24417251N
    Craig
    Regular Member sla002's Avatar
    hayes, middlesex
    hi mate.
    does sound like drop links, not really much else to change at the same time that won't cost a fortune, like they say if it ain't broke don't try fixing it. just do the drop links.
    pretty easy job only 2 nuts off, 2 nuts back on and nothing else to remove to get to it either. other than the wheel.
    £7 not a bad price, could try ebay.
    good luck.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    If your drop link is shot then change the arb bushes at the same time , the suspension loading would of gone onto the arb,s so you might as well change them at the same time .
    again a relatively easy job just two bolts holding the clamp , have a look at the how 2 for instruction,s .
    and still loving it
    Apr 2011
    Barnsley, Sth Yorks
    Cheers guys. Any links to arb bushes?
    Engine : 2.0DTi
    Mileage : 73350
    The arb bushes can come in 3 different sizes depending on your axle weight best bet is put the car on full lock with the driver side front wheel pointing outwards , and with a torch you should be able to read the part no off the bush top edge looking at your engine info, ( 120 cdti )the bush part no should either end in 1311 or 1312 the 1311 are 24.8 mm and the 1312 are 25.2 .
    That is if they are original bushes if they have been changed recently then you could have bushes with the revised part no,s ie 25.2s are now 9191188. best way is just have a look for yourself. then you will know
    and still loving it
    Apr 2011
    Barnsley, Sth Yorks
    anyone know where I can buy a cheap trolley jack and sockets and torque wrench as I dont have any tools
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    Quote Originally Posted by TheAdmiralCS View Post
    try halfrauds mate, I got a decent 2 ton trolley jack, axle stands, wheel chocks, a crawler and the jack handle doubles as a long bar with an angled socket for the wheel nuts, on ofer at the time for 39 quid, ftw
    Linky here, but still worth it at the current price
    http://www.halfords.com/webapp/wcs/s...k&iozone=PLPz1
    Apr 2011
    Barnsley, Sth Yorks
    Cheers for that Phil.
    Reserved it. now, what other tools do I need to do this job? Not got loads of £ to spend unfortunately either Might as well do this myself than pay a garage to do it really. Torque wrench's are crazy money too
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Don't worry about torque wrench just make sure there nice an tight.
    Think it's a 17mm spanner to hold the flats on back of ball joint. An 18mm socket to do the nuts.
    Apr 2011
    Barnsley, Sth Yorks
    Nice one, cheers
    Is this tool kit any good? Seems OK to me...
    http://www.argos.co.uk/webapp/wcs/st...uctInformation
  1. knocking from front, drop links?
    By martinmack in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2011, 22:43
  2. Drop Links
    By Exclusive BV in forum The 'Off Topic' room
    Last Post: 6th March 2011, 22:37
  3. Drop Links
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2010, 20:06
  4. Drop links
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 21:45
  5. drop-links
    By cpt slow in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2006, 20:41
