Results 1 to 10 of 15
Thread: Temperature read out
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default Temperature read out
    hi all before the cold weather started my temp read out on the display was always spot on , now the winter is approaching the read out seems to think the car is in sunny australia with an average readout of 27.5 c! is there a quick fix to this , or should i get it looked at (would it be covered under warrenty ? its not a major problem but you do expect things to work right.) thanks.
    Feb 2006
    north east
    sorry posted in the wrong section (please move ADMIN thanks)
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Could this be the temp sensor mounted behind from bumper been faulty. Seem to remeber this been covered before. Easy to remedy with a new sensor.
    Sure someone will confirm soon,
    Paul.
    Regular Member VectraV6CDTi's Avatar
    Wilts
    I had this problem with my last Vec. The temperature gauge kept going up slowly day by day. Took it down the Vx garage and they replaced the sensor I think.
    Moved for you..
    It is indeed a problem with our old freind the outside air temerature sensor..
    it's located centre bottom of the lower grille of the front bumper.. you'll see a wiring loom go to the centre of the grille.. access is ssooo easy, you can get at it by just lifting the bonnet.. sensor is held in with a silly plastic clip..
    Buy one and fit it yourself if you're out of warranty and save a pile of cash.. or if you've got warranty they can't fob you off now can they..
    Edinburgh
    Think mines on its way out as its reading 21c and its been frosty here all week.
    Regular Member david173's Avatar
    Dec 2005
    Dumbarton, Scotland
    Mines was replaced after reading a constant 70 degrees. If the temp is changing about, but its wrong, the calibration os probably out and if its static on some mad temp then its just ****d. Either way a replacement it required I think.
    Edinburgh
    Took out sensor as it was easy to find as described by Gsi3.2 and cleaned it up a bit,but now reading 25c.Will go to vx next as still under warrenty hopefully they will change it..
    They are a well known fault.. so i can't seen why they won't..
    south yorkshire
    Hi all!! Mines reading a constant F c. I imagine it's the same problem?
    Also where's the cheapest place to get a replacement as my cars out of warrenty
  1. Temperature changes
    By skene in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2012, 19:58
  2. Temperature
    By Wolfie01 in forum Engine & Drivetrain
    Last Post: 13th February 2012, 10:34
  3. No Outside Temperature.
    By lammy1961 in forum Insignia car chat
    Last Post: 30th January 2012, 15:58
  4. max outside air temperature...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2009, 11:03
