Thread: Cruse control fault
    Sep 2011
    OAKWORTH
    Default Cruse control fault
    my signum has had a few faults in the past 3 weeks on been the cruse control going off when on all on it`s own.
    and will not work for a few days but then just works again a few days later or a hour or 2 also.
    the vax-h garage said they had fixed it but it has happend again can any one give me any sugestions ?????/
    newport
    i'd check the brake and clutch switches
    Regular Member fishphone's Avatar
    May 2007
    Vehicle : Insignia Tourer
    Trim : Elite NAV
    Engine : 2.0 CDTI
    I would be straight back to garage as their previous work should have some kind of guarantee surely?
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Clutch or Brake pedal switches or the Stalk Switch would be my first choice when searching for the fault. If you can get it hooked up to a Tech 2 you can test the operation of all of these and watch for any faults as they occur.
    Jul 2011
    Aberdeenshire
    Had the same problem with my 08 Vectra Sri. It needed the CIM replacing.
    Sep 2011
    OAKWORTH
    Thank you all for your words of wisdom but im a virgin to do with new cars and all the talk so i will look into all that you have said and will let you know how i get on thanks again.
    Blantyre
    Brake switch and clutch switch are a 10 min job, break the old ones off and fit the new ones was easier as i found out, as Juggles says its prob the CIM, easy way to check is on the MWAY , slightly pull the stalk to you but dont flash your lights, then try to engage the CC
    When you pull the stalk out to have a look at it , look inside the CIM, there you will see 4 x spring contactors, these have prob been flattened and may be missing contacting the stalk or ver minimal contact, i used a piece of wire to "pull" them back up to a certain point, another member on her put some solder on his stalk connection area to assist with the contacts
    Hope that helps as i know what i mean
    Jan 2012
    OAKWORTH
    hellow again every one i started this blog on here and for sum reason i was kicked off the whole site so now on this name can any one help me with a part number for the cruse control stalk so i can purchase one and have it fitted while having a service doen and try saving a few quid. any help would be apreciated my car is a vaxhall signum eligance 2004 plate reg KP04XDE. tar an all yah guys take care.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    im having the same problem with the cc on the vxr switch it will work ok for a while then wont work till a reset ive read the codes off the car and it came up with cruise control switch malfunction and also no communication with canbus high speed??
    Nov 2010
    East Midlands
    Trim : design
    To operate mine I had to press the switch at least 3 - 4 times before it would operate - I couldn't get the stalk out but just sat in the car and kept pressing and releasing the switch (about 100 times). It now works first time every time. Obviously a bad contact in the switch but now resolved
  1. Trip computer & cruse control help
    By cooky76 in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2011, 22:47
  2. Cruise Control Fault.
    By pattz123 in forum Bodywork & Interior
    Last Post: 7th February 2011, 00:24
  3. Emission control fault.
    By rogerp in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 17:05
  4. ticking noise and cruse control
    By taylor280882 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2010, 16:49
  5. Cruise control fault?
    By jamesr in forum Engine & Drivetrain
    Last Post: 10th May 2008, 11:00
