Thread: Wrong parts form stealer
    Regular Member Razzemup's Avatar
    Dorset
    Default Wrong parts form stealer
    Hi,
    I am looking for the 4 bolts that go on the crank alternator drive belt pully . Dealer has given me 93191382 but they are to short. Sorry can't post in request section.
    Diesel 1.9 CDTi 120 PS, engine code Z19DH (UK)
    Engine : 1.9 CDTi
    Post
    Z19DH engine?
    They have given you SCREW, M8 X 56.5, DAMPER TO CRANKSHAFT
    17205097 - 93191382 20 05 758 4 N
    For Z19DTL,Z19DT DIESEL ENGINES
    Quote Originally Posted by Razzemup View Post
    Hi,
    I am looking for the 4 bolts that go on the crank alternator drive belt pulley
    What is it you need as the crank and alternator pulley is different
    Looks like both Z19 engines use those bolts (x4) to hold the crank pulley on. Are you sure its located correctly on the crank?
    Dorset
    Sorry lump is Z19DT. The 4 bolts I need are the crank pulley bolts. The pulley is defiantly located correctly and the old bolts screw in. (changing bolts as they are a bit chewed). Has the pulley design been changed since 2005?
    Engine : 1.9 CDTi
    Can you screw the new bolts in without the pulley on to check they are M8 and can you put an old and new bolt side by side to see the difference in length.
    They do list 2 pulleys and 2 lots of bolts but the other bolt is only slightly shorter.
  1. Car pass form vx
    By antowens in forum General Chat
    Last Post: 3rd December 2012, 18:51
  2. how do you put pictures in form please
    By myelite150 in forum The 'Off Topic' room
    Last Post: 2nd April 2010, 00:08
  3. Stealer price for parts please
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2008, 02:22
  4. Would a stealer use the wrong grade oil in a service?
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2008, 01:08
  5. my Bro on TOP form again..
    By Silver V in forum General Chat
    Last Post: 26th October 2007, 22:43
