Thread: Turbo Died Then Resurrected
    Catterick, North Yorkshire
    Default Turbo Died Then Resurrected
    Hi i was driving oop norf on saturday just got onto M25 and went to overtake a car and noticed not much happening when putting my foot down, hit the throttle a few times and there was no pull whatsoever, 2 mins later engine management light comes on dash pulls off motorway and it was like the turbo wasnt kicking in car was like a real slug struggling to pull so i stopped turned engine off left it for 5 mins and started up again and all was fine, been fine ever since anyone reckon i should take it in to dealers to get it checked out! oh nearly forgot its a 1.9 cdti 150.
    Regular Member Strummerd's Avatar
    May 2006
    Evesham
    Looks like the car went into limp mode when the ecu detects a fault,could be anything usually a sensor somewhere.If it re-occururs get it to Vx as the fault will be stored in the ecu. I had simular fault and it was the crank sensor at fault.
    Feb 2006
    Dorset
    mine did the same going up the A303 near podimore roundabout , i did have some berk in a vw sat up my yarseso cracked it open in 4th and 5th got to 4.5k in 5th and thecar with a spanner through the roof lit up , quickly flicked the ign off the back on and left him behind .....
    The oly way to find out for sure what the issue was is to get it into the dealer before you have done 20 restarts.. it will still be a 'live' code then and more easy for them to trace..
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    Quote Originally Posted by Gsi3.2
    Never knew that....... So after 20 restarts the recorded fault is effectively archived and not easy to trace.
    I wonder how many other people simply thought that once the fault was logged then that was it. Is this just peculiar to VX or an industry standard?
    AFAIK is just all down to how the ECU is designed..
    Having worked on FFAARR too many vauxhalls, i just really know about their particular ECU's and what they do.. The Ren-nooo's that i've laid my hands on have a similar arrangement but i don't think that it has anything to do with a 'standard'..
    However.. since the introduction of 'OBD' and 'CAN' compliant cars it may now be a feature of them.. i'll just have to get under the bonnet of a wider range of cars to find that one out for you..
    Feb 2006
    Dorset
    Renaults start clearing codes after a set time , because if they didnt they would run out of room for storing them , renault are trying to fix the problem by fitting 30gb hard drives ......
    still not enough storage space!!!
    3 ren-NOOOO's in the family still... but one's going!!!
  1. Vectra has died, turbo goosed!!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2012, 17:52
  2. Has my Turbo died? Vectra C 1.9 cdti 150 16v
    By Mission1979 in forum Engine & Drivetrain
    Last Post: 10th August 2012, 00:07
  3. Car has died!!!! Please help
    By MORGIE8153 in forum Engine & Drivetrain
    Last Post: 9th December 2011, 17:00
  4. cut out and died
    By mabski in forum Engine & Drivetrain
    Last Post: 1st March 2011, 10:47
  5. Turbo Died Vectra 120 8v
    By mani911gt3 in forum Engine & Drivetrain
    Last Post: 16th November 2010, 18:20
