Results 1 to 10 of 11
Thread: retro fitting headlight washers
    newport
    Default retro fitting headlight washers
    is it possible on the vec c?
    does it use a larger washer bottle and extra pump like the vec b?
    i done this to my old vec b, by wiring up a relay and connecting to the sidelight power and the windscreen washer power, so they would only come on if the headlights were on.
    would this be ok on the vec c or would the canbus light wiring cause an issue?
    could you even use the headlight washer setup from a vec b on a vec c?
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Yes its possible, a few of us have done it now.
    http://www.vectra-c.com/forum/showthread.php?t=15101
    newport
    cheers for the link, looks a lot more complicted than the b setup, and the fact you have to get it activated too, not to sure now
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    m8 its easy to add the wiring if you havent already got it present,ive
    done a fair few without any problems
    gwent
    Talking
    I am in the middle of doing this upgrade just waiting for the parts to come not brought a washer bottle with all the pumps on of eBay and a big thanks to DasArab for getting me the headlight washer pump plug and lead I can do my own tech 2 so come next week it will be fitted
    newport
    how much would tech2 normally cost?
    its a good how2 but to confusing for me to grasp with one read lol.
    but basically, first step is to check the pins where the relay sits, and check if i have the plug at the washer bottle?
    then its just a case of actually fitting the bits, and plugging it all in, then tech2 to activate?
    do the parts have to be vec c, or are they the same as vec b/omega? (just to widen the search)
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by taffy bhoy View Post
    Correct. Theres pretty much a good chance of someone near by with tech2 or opcom that will be able to activate it for you for a beer token or 2. If youve got HIDs fitted you can get them activated at the same time too. Things like the 3 way non return valve and connectors to the washer jets fit from the omega, and the pump is the same, but after that Im not sure.
    newport
    cheers mate, will have a looky tomorrow see what i have, damn these vec c's, everything has to be turned on with tech2 lol
    on my old vec b gsi, i retro fitted facelift xenon headlights, fitted rear electric windows, changed steering wheels, fitted headlight washers, all easy jobs, different story on the vec c's lol
    newport
    well had a look today (and a feel lol).
    the space where the white relay sits, the pins are there. i felt under the bumper and can feel 2 plugs, one is a small one (i assume level sensor) and the other is bigger and sits higher up, which i assume is the plug for the headlight pump.
    so it looks like all the wiring is in the car. so i assume i just need to get the jets, piping, larger washer bottle, headlight pump, and then tech 2?
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Heres what the plug your looking for looks like. So after that yes, ebay and GPS are the best places to search for bits, or its down the dealer with about £200 in your hand.
  1. Retro fit Face-Lift Headlight Washers
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 13:35
  2. Retro Fitting Headlamp Washers
    By PedroMV6 in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2010, 20:16
  3. Retro fitting AFL & Washers after HID kit installation.
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 22:27
  4. Headlight washers
    By rockh in forum Styling
    Last Post: 30th July 2009, 22:14
  5. headlight washers.
    By Netstar in forum Bodywork & Interior
    Last Post: 2nd March 2009, 16:18
zafira b headlight washer fit
retro fit vectra c gsi headlight washer jet
how to access headlight washer vectra c
