Results 1 to 2 of 2
Thread: Engine Removal
    Jan 2010
    Leigh, Lancashire
    Default Engine Removal
    My vectra's waterpump gave up yesterday resulting in the cam belt slipping and killing the engine. So I am wanting to stick another engine in.
    Its the Z18XE engine , is there are 'hot to' guide on removal of these engines. I have good experience of taking out Rover engines, just none of Vauxhalls lol.
    Also, can I just fit another same year z18xe engine straight into the car, or will I need all the ecu etc etc?
    Thanks in advance
    Tom
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    A few of us changed Justin's 1.8 when it went bang big style (5 inch hole in the block) on the way home from a meetup once.
    Certainly not a howto, but info is here http://www.vectra-c.com/forum/showthread.php?t=131435 (along with lots of goofy pics of us doing it).
    To be honest, the easiest way is to replace the engine itself but use all your old ancillaries, ecu's etc then it should just start and run. If you start swapping ecu's and stuff you'll need a fairly major tech2 session to get it all working again.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Fuel filter crash box removal mod - 1.9cdti engine
    By alcutler in forum Engine & Drivetrain
    Last Post: 22nd May 2011, 23:19
  3. Engine management after airbox removal.
    By !tf in forum Vectra C / Signum Troubleshooting
    Last Post: 30th April 2011, 13:51
  4. z22se Engine Removal
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 9th February 2010, 23:00
  5. Help with removal of engine cover on 2.0T
    By joules2.0t in forum Engine & Drivetrain
    Last Post: 27th October 2007, 13:19
vectra engine removal
opel 1.9tdci engine remove
vectra c z18xer engine remove
remove engine vectra c
remove vectra c engine
2005 vauxhall vectra petrol engine. engine removal
engine removal on vauxhall zafira 1.9 Tdci
