Thread: SatNav Not working
    Oct 2009
    New Marske
    Default SatNav Not working
    Vectra C 56 plate 3.0 V6 Elite
    Satnav screen is blank and cannot eject the CD, pressing the Navi button does not work either.
    Radio, Computer and CD work still,
    Any ideas..?
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I had this after two days of owning the car.
    The CD got stuck after my 6 year old son decided to continously press the eject button as he found it funny.
    I know this sounds a bit rough but give it a whack on the side of the centre console whilst pressing the eject button. Might have to do this a few times for it to come out.
    Once out (hopefully) then clean it. Then re insert it. All should work fine afterwards if the CD is not too scatched.
    Mine was a right pain to get out but once out, cleaned and put back in, it has behaved itself fine for the last 12 months and still going.
    Hope this helps
    Good luck.
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    mines done exactly the same i just live without it now as vxl want 1300 for a new cd70 unit
    everything else works apart from the navi its died i know its not the drive as i have tested it and i`ve had the unit to bits as well . Eventually i will probably swap it out for a touch screen
    Nov 2010
    Northampton
    Did you ever find out what caused this? Mine ie exactly the same, can't even get the disc out with bashing. It's since I had a flat battery and changed the alternator.
    Please PM me if you can help, thanks.
    Cheers,
    Rog
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    what you need is an old bank card and some double sided tape
    put some tape on the end of the card and carefully push it inside keeping the tape as high as possible till its about half way in then let the double sided tape end drop down, then press the eject button whilst pulling slightly on the card your disc should come out attached to the card
    normally its just got stuck on the holder for the disc inside
  1. CD70 satnav not working
    By davidj387 in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2012, 23:44
  2. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  3. Replies: 4
    Last Post: 11th November 2011, 12:05
  4. Replies: 0
    Last Post: 10th November 2011, 22:58
  5. Post codes in CD70 NAVI satnav - who has this working ?
    By eeyore in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2011, 16:09
