Thread: cruise control Cockpit light
    Portugal
    Default cruise control Cockpit light
    Hello, I own a vectra c, I live in Portugal, and I have a question that I am not able to clarify here.
    In the cockpit has to see the light of the cruise control? Is that my car does not appear!
    The light also does not appear the least? How can I solve this?
    My English is basic I apologize for that?
    Apr 2011
    Toulon, France
    Hello Betus.
    Do not worry about your English. It is better than my Portguese
    Does your cruise control work? May be a blown bulb on your dashboard?
    x
    Regular Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Does the cruise control work, but the light does not?
    Full Member
    Bristol
    Default cc
    You know when you drive off you have to activate cc by touching the brake pedal.
    Portugal
    The cruise control works perfectly, but in fact I do not see the light turn on. May be a blown bulb on my dashboard.
    It will be a fuse, since the lamp does not light up ...
    Full Member
    Bristol
    if it was a fuse the cc would not work so I think it may just be your bulb blown.
    Engine : 1.9 CDTi
    Has it ever worked?
    Loads of references to a bulb being used for the CC indication light.
    It's actually an LED, as are all the other warning lights in the speedo pod.
    Despite the handbook saying that the CC light should come on as a check light when the ignition is first switched on, it doesn't, so you can't actually see if the LED has failed.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    get somebody with opcom or a tech 2 to do a cc bulb test.
  1. Intermittent cruise control & oil can light...HELP NEEDED
    By simmo3187 in forum Engine & Drivetrain
    Last Post: 12th July 2012, 14:06
  2. Cruise Control dashboard light not working
    By Weaselbert in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 15:30
  3. Activate cruise control and low oil warning light comes on??!!!
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2010, 00:16
  4. Cruise control dashboard light
    By superstuper in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2008, 11:17
  5. Cruise control failure, Engine light
    By stevedee3 in forum Engine & Drivetrain
    Last Post: 13th November 2005, 11:00
