Thread: Vectra springs on a Signum
    Regular Member KeefyB's Avatar
    Sep 2009
    Warminster
    Default Vectra springs on a Signum
    I know this question has been asked before and ive spent the last half hour trying to find the threads, BUT
    Will the -45mm lowering springs from a 2.0 dti vec be ok to put on a 2.0dti signum?
    Full Member
    Bristol
    Well I have just checked and no vectra part no's are the same as yours. I can't tell all I know is that they list different springs fo pre facelift and facelift vectras but the do fit. So I can't see any reason they will not fit.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I was thinkin about this can anyone confirm Vectra springs will go on a siggy please
    lincolnshire
    the signum runs the same springs as the estates so i think you'll find that it will sit way too low on hatch/saloon springs
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The fronts would fit fine, but the rears are slightly different.
    I had this problem recently as I wanted to lower my estate more than the standard 30mm that most companies supply. If you have a hatchback it's easy there's several companies that do more than 30mm drop springs for the hatch/saloon.
    For an estate however (the Signum is the same chassis), the ONLY company that makes springs with a bigger drop is H&R. Fitted their 40mm drop springs on mine recently with Bilstein B6 shocks and it's a fantastic drive.
    Sep 2009
    Warminster
    fanx for the input gents, may have to try h&r springs then Ian
  1. Vectra Estate / Signum springs
    By Celes in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2010, 23:03
  2. vectra-signum front springs
    By Dom_cdti in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 12:44
  3. Front coil springs on Signum/Vectra C
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 23:35
  4. Does signum springs fit vectra estate?
    By vectra_andy in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2007, 07:23
