Thread: Replace turbo on 2.2 diesel?
    Nov 2010
    Coventry
    Default Replace turbo on 2.2 diesel?
    Hi all, I have read through all the posts/threads on turbo failures I can find but I have yet to see any comments on how difficult they are to replace.
    Is it just a simple bolt on and off for a have a go type like me or should I be seeking proffesional help?
    The first quote I have received is for £1200 supply and fit.
    The green flag guy told me that I should be able to pick up a reco for £250-£300- that means that the garage are stinging me for £900!!!!
    I also reead an onld thread that anyone thinking of replacing a turbo may as sell pay a little more and go for a complete recon engine?
    Any advice would be welcome
    p/s the green flag guy said that the bearings had gone but the impellors were intact. - not sure if this helps.
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    recon turbos can be had for £350 with 12 months warrenty the vauxhall diesel engine is pretty bullit proof the only thing that really lets them down is the fuel pump
    Regular Member Thom's Avatar
    Nov 2010
    UK
    As far as im aware (and i may be wrong) but the turbo is easy enough to get on and off - its just a matter of unscrewing stuff and bolting it back on in the correct places but could take a good days work for a normal home mechanic.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Thom View Post
    Most mechanical jobs on cars is just a case of unscrewing stuff, what is comes down to is how much you have to unscrew
    The turbo on the dti is very easy to get to and almost as easy to change. It's right at the top of the engine and the hardest bit will be getting the exhaust bolts off and then when putting it back together making sure the oil feed doesn't leak
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    very true i would get new copper washers when putting it back together
    Regular Member Innes's Avatar
    Plymouth
    Run the engine for a short while. Just enough to heat up the bolts. That'll make it easier to undo.
  1. Insignia Bi-turbo diesel
    By mattv6diesel in forum Insignia car chat
    Last Post: 27th February 2012, 15:50
  2. V6 diesel replace clutch
    By daviek72 in forum Engine & Drivetrain
    Last Post: 28th April 2010, 21:04
  3. 3.0V6 cdti turbo failure - any How2 replace advice?
    By littlejohn in forum Engine & Drivetrain
    Last Post: 19th February 2010, 00:50
2.2 diesel vectra c turbo
how much for replacement turbo for a 2.2 diesel vectra
