Thread: Would you trust the dealer with this....
    Dec 2010
    Cumbria
    Default Would you trust the dealer with this....
    Took it in for a injector seal. Got a quote for 1 seal replacement at £99. 10 mins later a callback saying 2 have to come out....at £179.
    I thought here we go!!
    Left the car and went for a walk around. Got a call saying there was a problem could i pop in.
    Went in and got a whole list of things that they reckon need doing.
    The front tyres were new at the end of June so are only 3 months on!!
    There is no knocking from the front AT ALL and the car feels very safe and sound.
    I think they are trying it on TBH.
    What do YOU think? Should i take their word for it? Am gonnna replace the rear brakes myself and possibly the drop links. Might even tackle the front coil springs.
    Just so shocked that a £99 job has suddenly morphed into a £1900 job!
    Are they Halfords in disguise????
    Get them to show you the work that needs doing on the car and why it needs doing. Especially the tyre which apparently has 0mm tread on the inside...
    Regular Member accveccysriturbo's Avatar
    Jul 2010
    west mids
    I dont trust any VX dealer after being told i needed my timing chain replaced and two rear shocks needed replacing - £1000 or above I forget now.
    What was wrong? The wastegate on my turbo was loose and I changed all 4 springs two weeks later for eibachs, and then sold the 4 springs on here. None of them were broken!!!
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    +1 i would get them to show me everything
    Glasgow
    If its not had a cambelt kit change at 100k miles then that is highly recomended to be changed.
    If the injector seals are leaking i would look to replace them.
    If one coil spring is broken then ideally the pair do need replaced, thats an MOT failure.
    Top your engine oil upto the max line yourself.
    The rear right O/S/R tyre will need changed soon as 1.6mm is the legel minimum assuming 0mm on the edge is incorrect. Again would be an MOT fail.
    If your happy theres no knocking or play in the steering then dont worry about that but if its excessive it will fail its next MOT.
    Dec 2010
    Cumbria
    The oil i will defo do. Was thinking about changing anyway.
    The drop links are ordered, as are the springs and brake pads.
    Am i right in thinking that there is only one spring that needs changing at the front? The spring that the strut goes through? Might as well change both of them too as they are only £28.
    There is no knocking at the front at all and i thought if a spring had snapped, firstly we would of heard/felt it, and secondly that the car would feel awful on cornering.
    Cheers for the advice though guys! Nearly had a heart attack when they said £1900!!!
    Dec 2010
    Cumbria
    Also...i had considered Warranty Direct when i bought the car. Do you think they woud of covered any of the above??
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    When i took mine in for the handbrake recall they gave me a list of jobs needing doing. One was a broken rear spring... Fair enough but i got a set of 4 eibachs for less than they wanted for 2 standard rear springs... Then i took the rest of the list to the garage I use that i know and trust and low and behind the rest of the things were absolute pish...
    Cant remember what they were now as this was 2 years ago but it was also a hefty cost! Robbing beggars... I just put it down to them having to do the recall at their cost so wanted to make some money out of me another way
    Glasgow
    Quote Originally Posted by cammy3000 View Post
    Just good practise to change them both.
    Most of the time you wont know if its broken as its usually right at the bottom or top of the coil.
    They wont cover any faults that are already present i think you have a certain period of time before you can make a claim. Most of the stuff you have listed is wear and tear and probably would'nt be covered anyway.
    Are you going to get your cambelt done as over 100k miles is pushing it and no point spending money fixing replacing bits and bobs if you have a serious failure 6 months down the line.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Run the other way as fast as you can.
  1. Trust Dealers!!!!! WTF
    By tolly in forum General Chat
    Last Post: 28th April 2011, 21:08
  2. Trust it comes back ok
    By Angel Boy in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2007, 09:31
  3. Trust or stupid?
    By AJA in forum Comedy & Humour
    Last Post: 9th June 2006, 18:42
  4. Don't trust anyone!
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2006, 21:58
  5. Never Trust A Dealer!
    By Gazza in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2005, 21:03
